- Thank you received: 1
Starter Clutch: '81 KZ 750 LTD (4 cyl)
- davehayward1
13 Sep 2009 17:53 #321407
by davehayward1
Starter Clutch: '81 KZ 750 LTD (4 cyl) was created by davehayward1
I’m trying to remove the starter clutch to replace springs, rollers and caps
Got the exhaust system off. Got the clutch out. Got the oil pump out.
Got the secondary shaft nut off
Now - my “Clymer Manual†says to tap on the left end of the secondary shaft until
the right end pushes the right bearing out - done.
Now - it says to “pull the secondary shaft out of the clutch side of the engineâ€
The secondary shaft won’t pull out, as starter clutch and the starter clutch gear do not slide off of the secondary shaft
Are the gear and/or starter clutch attached to the shaft?
- bountyhunter
- Thank you received: 337
13 Sep 2009 18:47 #321421
by bountyhunter
Replied by bountyhunter on topic Starter Clutch: '81 KZ 750 LTD (4 cyl)
Maybe somebody here has a link to the factory manual. You probably need to get one to have in the shop. They really are great.
- JR
- Thank you received: 448
13 Sep 2009 18:53 #321424
by JR
Replied by JR on topic Starter Clutch: '81 KZ 750 LTD (4 cyl)
You can find a copy of the shop manual here towards the bottom of the page
www.mbsween.com/kz750l3/index.html
courtesy of mbsween who is a member at kzr. I havn't looked at it in a while but am sure the info you need is in there.
Good luck
Good luck
