cam timing help needed on a z650-f2
- Aumriff
13 Sep 2009 02:02 #321251
by Aumriff
KZ650 F2 (1981 UK/Euro model)
K+N Pods, Marshall 4-1 exhaust
Living in the UK
cam timing help needed on a z650-f2 was created by Aumriff
Hi all, I hope someone here can help me.
My manual states that the exhaust cam mark (z6ex) lines up with the cylinder head surface at the front and the intake mark (IN)lines up with the head surface, pointing towards the carbs. The pin count from the EX mark to the IN mark should be 45/46 pins. Now, here's the problem....
Both of my cam sprockets look nothing like the manuals' version. Each of mine have an EX mark with an arrow next to it, an Arrow on its own and an Arrow with a T next to it. The link pin count is 36 from front of cylinder head surface to back of head surface. I've tried various combinations of cam positions using the different marks. I've either had valves hitting each other when hand cranking or if the valves don't collide and I run the engine it back fires through the carbs. Please could someone shed some light on my problem? How many link pins from one mark to the other and which marks do I actually use? Any help would be appreciate.
Living in the UK
- chance
- Life long biker/
13 Sep 2009 04:45 #321255
by chance
Replied by chance on topic cam timing help needed on a z650-f2
- Aumriff
13 Sep 2009 07:43 #321291
by Aumriff
Living in the UK
Replied by Aumriff on topic cam timing help needed on a z650-f2
Thanks for the picture. I'll go to the shed now and try to reset the cams as shown in the photo. I can't quite make out if the arrows are the ones with 'T' next to them or the arrows that are on there own but I'll take an educated guess at which arrow is correct going by the cam lobe position in the photo for cylinders 1 and 3. I'll be back on here later to thank you once again if it works or to ask for more help if it doesn't.
Keeping my fingers crossed.
Living in the UK
- Aumriff
14 Sep 2009 06:10 #321524
by Aumriff
Living in the UK
Timing problem solved. Running well apart from a bit of fuel spitting back out of the carbs into the pods. Thanks for your help with this. Off to the Carb threads to see if I can solve the fuel spitting problems.
Living in the UK
