KZ650 - rattle between 4100-4200 rpm's
- Phildo
11 Sep 2009 07:38 #320642
by Phildo
KZ650 - rattle between 4100-4200 rpm's was created by Phildo
seem to have a rattle between about 4100 and 4200 rpm's. Outside of this small range its fine. I hear it in every gear (including N just revving), and on both accel and decel. The noise seems to be distinctively from the front right of engine, but we all know sounds can be misleading.
Its an '81 with just over 6k on it.
One idea I had was maybe motor mount. I haven't had a chance to check it. Anybody else had this or an idea of what it may be?
Thanks
Thanks
- 9am53
- homebrew, and some bbq
- Thank you received: 3
11 Sep 2009 08:00 #320645
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic KZ650 - rattle between 4100-4200 rpm's
I have something similar, here is my thread about it. I am doing a valve adjustment and some other work this winter to hopefully alleviate the problem
kzrider.com/index.php?option=com_kunena&...d=2&id=313551#313837
'84 GPz900r
'71 CB350
- Phildo
11 Sep 2009 09:28 - 11 Sep 2009 09:28 #320659
by Phildo
Replied by Phildo on topic KZ650 - rattle between 4100-4200 rpm's
got off work early today, motor mount bolts all checked out tight.
here's a small video of what I hear...
s495.photobucket.com/albums/rr314/xphild...ent=EngineRattle.flv
Last edit: 11 Sep 2009 09:28 by Phildo.
- lapeerray
11 Sep 2009 13:46 #320717
by lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
Replied by lapeerray on topic KZ650 - rattle between 4100-4200 rpm's
sounds like a vibration ,check all your exaust mounts.
- Phildo
11 Sep 2009 15:11 #320780
by Phildo
lapeerray wrote:
now I cannot get that screw back in LOL
Thanks guys!
that led me to the rattle. it is the forward screw on the exhaust cover around the H-pipe. took it off, rode a bit, i had the vibration that everybody speaks of, but the rattle is gone!sounds like a vibration ,check all your exaust mounts.
Thanks guys!
