1,4,2,3?
  • lemo32
  • lemo32's Avatar Topic Author
  • The Price of Cool aint cheap
1,4,2,3?
17 Mar 2006 16:00
#32041
if im sitting on the bike would no. 1 cylinder be far left, 4 next and 2 then 3. getting ready to set cams and the book says make sure 1 and 4 are top dead center but didnt say how they are numbered.
1979 kz 1000 06 katana 750
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: 1, 2, 3, 4
17 Mar 2006 16:12
#32042
Front
1, 2, 3, 4
Rear
Right side up
Post edited by: Duck, at: 2006/03/17 19:12
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: 1,4,2,3?
17 Mar 2006 17:31
#32067
1 & 4 are the outside cylinders and 2 & 3 are the middle two. 1 is on the left side of the bike.
1 & 4 rise and fall together and 2 & 3 rise and fall together. When 1 is at TDC, 4 is also (unless the crankshaft is bent or twisted) while 2 & 3 are at BDC (180 degrees offset).
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 1,4,2,3?
17 Mar 2006 17:45
#32070
What is the firing order?
1342?
Or are 1 and 4 at TDC on the compression stroke at the same time, and 2 and 3 ? In which case the firing order will be 1&4 at the same time then 2&3?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • hydrolazer
  • hydrolazer's Avatar
Re: 1,4,2,3?
17 Mar 2006 18:15
#32077
even though the pistons are both up at the same time, the valve timing is 180 degrees away from each other. if number one cylinder is on the compression stroke getting ready to fire the air/fuel mixture, number four cylinder is on the exhaust stroke. you will get spark to both plugs at the same time but the exhaust valve will be open and is pretty much a wasted spark but that is normal
\'79 kaw 1000 ltd
  • The Milkman
  • The Milkman's Avatar
Re: 1,4,2,3?
17 Mar 2006 22:11
#32124
rstnick,,, I have always thought that the firing order for these was 1342 also, as any 4 cylinder I have ever worked on was. But I was corrected and had to check for myself.
If you look at the camshaft the order is 1243. Don't know why they did it that way, but they did.
Les
  • btchalice
  • btchalice's Avatar
Re: 1,4,2,3?
17 Mar 2006 23:38
#32130
with 2 seperate coils 1,4 fire at the same time at every revolution and the same for 2,3 if you switch the plugs between 1,4 or 2,3 it will still run
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • ltdrider
  • ltdrider's Avatar
Re: 1,4,2,3?
18 Mar 2006 10:25
#32213
Milkman's right.
1, 2, 4, 3 is the firing order.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
