Timing Chain Issues - 650
- reborn650
09 Sep 2009 08:39 #320140
by reborn650
-1998 Jeep TJ Wrangler 4.0...
Timing Chain Issues - 650 was created by reborn650
Hey gang. It's been a while since I had the head off my 650 and brought it into the machine shop to get them to give it the once over.
Putting the head back on after a valve adjustment and setting up the cams I found this issue. As I mentioned, it has been a couple of years since I had the 810 built and I want to check to ensure that I haven't screwed up anything before I light 'er up.
Here is a little background info.
1977 Kz650 bottom end. 750 jugs bored out to 810. Gpz750 cams, intake valves. Stock roller chain, APE cam chain adjuster.
Set the ignition mark to 1-4 setting with cylinders 1/4 at TDC.
Lined up the exhaust cam to the head surface, same on the intake cam, counted 36 pins backwards from the correct marks and ensured there was no kinks in the chain. Torqued down the cam caps.
Installed the top cam chain guide and pushed down to make sure the slack was taken up.
Turned in the APE adjuster to where it was touching the chain and backed out 1/4 turn.
Now when I roll over the engine with a socket on the 17mm bolt, the engine turns over nicely but a couple of times in the manual rotation the chain slightly drops under the top cam chain adjuster. It almost makes a popping type sound when the chain drops. The chain doesn't jump a tooth as the marks are still lined up on the cams when the 1/4 ignition marks on the points plate are lined up.
All the shims are in place under the lifter buckets and the plugs are out when I am rotating the motor by hand. Nothing looks out of place on the top end.
The bike has only about 20,000 miles on it and when I checked the cam chain stretch the links were still within the factory tolerance levels.
So any pointers on why the chain might be dropping? Is this normal?
- Mark Wing
- Thank you received: 22
09 Sep 2009 08:49 #320142
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Timing Chain Issues - 650
I think there's still some slack in the chain.
Mark
Mark
Yorba Linda Cal.
- MadMac74
09 Sep 2009 13:03 #320199
by MadMac74
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
Replied by MadMac74 on topic Timing Chain Issues - 650
Thats kinda what I was thinking. Or maybye one of your Idler wheels (for the camchain) is starting to go, causing excessive slop?
good luck:)
MAC
good luck:)
MAC
- timebomb33
- Thank you received: 10
09 Sep 2009 17:35 #320261
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Timing Chain Issues - 650
sounds like loose cam chain to me as well take it back to tdc on no'1 then readjust your cam chain tension again.
- reborn650
09 Sep 2009 18:36 #320277
by reborn650
Replied by reborn650 on topic Timing Chain Issues - 650
Thanks gang - APE tensioner is installed properly. I am leaning towards Mark's suggestion. I pulled the chain tight then rolled it by hand probably only ten links before I started setting up the cams. This time I am going to get my son to turn the 17mm socket and complete one full revolution of the engine back to the 1/4 marks while keeping the chain taut up on top.
I'll let you know my diagnosis of my flub which was quite likely a result of just rushing to get everything buttoned up and fired.
I know this motor inside and out but once in a while everyone of us makes a rookie mistake:-)
