- Thank you received: 3
dumb timing question
- 9am53
- homebrew, and some bbq
09 Sep 2009 07:38 #320127
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
dumb timing question was created by 9am53
Hey, lets say I check my bikes timing with the strobe light, and my timing is off. Do you just turn the pickup coils to adjust it? :blush:
'84 GPz900r
'71 CB350
- mzandmz
09 Sep 2009 07:50 #320129
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic dumb timing question
DUMB ANSWER- NO.:dry:
- mzandmz
09 Sep 2009 07:51 #320130
by mzandmz
- sarge383
09 Sep 2009 07:51 #320131
by sarge383
kz 650d2 sr 79
Replied by sarge383 on topic dumb timing question
you have to check timing for both sets of points use the f mark for your test there are a couple threads here that have a little more detail just do a quick search for them
kz 650d2 sr 79
- Sandy
- Fly High,Tony
- Thank you received: 13
09 Sep 2009 08:27 #320137
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic dumb timing question
I don't think your bike has points...does it? :huh:
82 LTD?
82 LTD?
1977 KZ1000 A-1
- loudhvx
- Thank you received: 1616
09 Sep 2009 08:27 #320138
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic dumb timing question
9am53 wrote:
The pickups are on a timing plate, which, theoretically, should rotate in order to adjust the timing. However, in the U.S., the timing plate mounting holes don't have slots, so the plate can't be rotated.
To fix that, you have to remove the timing plate and file the mounting holes into slots. If it's really far off, there is probably some other problem.
The pickups have magnets which must be installed in a particular fashion in order to work. If you remove the pickups in order to prevent the filings from sticking to the pickups, remember how the magnets went on so you can put them back exactly the same way.
Another thing you can do to adjust the timing is to pull off the iron pointer-slug from the rotor shaft and put it back on in a different orientation. This has to be done very carefully so as to not damage the pointer or the shaft.
1981 KZ550 D1 gpz.
Other links.
- 9am53
09 Sep 2009 09:23 #320148
by 9am53
'84 GPz900r
'71 CB350
Replied by 9am53 on topic dumb timing question
Thanks loudhvx, that is what I was looking for.
'84 GPz900r
'71 CB350
