Alternator Cover Swap question
- KOOL RYDER
- KZ 650B2 / KZ 1000E
08 Sep 2009 14:11 #319930
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Alternator Cover Swap question was created by KOOL RYDER
Simple question.
I bought a new alternator coveer off ebay....nice and shiney. Will it be as simple as taking the screws out and replacing the new cover? No surprises, the cover will just come off, eh? 78 650B.
KR
KR
1978 KZ650B
1979 KZ1000ST
- Vter Bob
- Thank you received: 4
08 Sep 2009 18:27 #320013
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
Replied by Vter Bob on topic Alternator Cover Swap question
I'm not 100% sure with a 650 but I think the answer is no. The alternator cover has the stator attached to it on the inside. There are also wires that pass through a rubber grommet. To disconnect these wires which run to you reg/rec you will have to remove the the sprocket cover also. If the 650 is anything like a 1000 you will also have to remove shift lever, peg mount bracket and starter cover. None of it is hard to do. Oh, if the new cover didn't come with a stator you'll have to swap yours over.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- kzr750r1
- Thank you received: 9
08 Sep 2009 18:37 #320014
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic Alternator Cover Swap question
Still simple though, even with the alternator inside.
