Valve cover leaks
  • Wile
  • Topic Author
  • Kawasaki is Japanese for money pit
08 Sep 2009 09:25 #319869 by Wile
Valve cover leaks was created by Wile
The bike in question is a 75 Z1B 900 that was opened up to 1075. When I first got the bike last year, it would weep oil from around the rubber cam ends. (AKA Rubber baby buggy bumpers). Checked valve clearance and put on a new blue gasket from Z1 Enterprise. Leaked even more around the buggy bumpers. So I pulled off the cover again and put in aluminum buggy bumpers from APE as well as a new blue gasket. . Also put in a light coat of permatex on all surfaces. Still freaking leaks. I can even see a bit of oil coming from under the bolt heads. I know the mating surfaces are flat and true. I don't think it's from over compression as the engine has about 5000 since it was opened up to 1075.
One thing I looked for but could not see was, where does the cam get it's oil from for lubrication and how does it get back to the pump from that area? I noticed small pools of oil by the buckets. Could the return be blocked? Maybe I need to put in some type of breather up there.
This is really ticking me off. If I wanted a leaker I'd have gotten a Harley.:P
One last question. What the heck are the rubber cam ends for?
98% of all Harleys ever sold are still on the road. The other 2% made it home.
“I'd rather be riding my motorcycle thinking about God than sitting in church thinking about my motorcycle”
"Only a biker knows why a dog sticks his head out of a car window"
08 Sep 2009 09:32 - 08 Sep 2009 09:33 #319873 by MadMac74
Replied by MadMac74 on topic Valve cover leaks
Just a thought ,, Check you crankcase breather...yer engine may be building pressure in the crankcase,if its plugged, and causing your weepage ! Good luck!B) ;)
A cracked valcover will do this too..
MAC:)
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
Last edit: 08 Sep 2009 09:33 by MadMac74. Reason: ...
08 Sep 2009 09:37 #319874 by keith1
Replied by keith1 on topic Valve cover leaks
put 1194 sealer around rubber end plugs and retorque valve cover bolts after the first 3 rides...i had the same problem....now..no leaky.....
08 Sep 2009 10:22 #319878 by arai59
Replied by arai59 on topic Valve cover leaks
Those are cam end plugs. Often due to age they get hard and leak. Especially if they have been moved. You can buy bew ones as well. I use Hondabond 2T on assembly. Never had a leak. They are there to fill in the area after the cam journals were line bored at the factory.
08 Sep 2009 13:19 #319920 by Old Man Rock
Replied by Old Man Rock on topic Valve cover leaks
WHEN INSTALLING THE ALUMNIUM END CAPS....
Did you level and seal them in place?
When I got mine, I had to mill them down (file) flush to the head decking....
Just a thought...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
08 Sep 2009 19:01 - 08 Sep 2009 19:03 #320022 by bountyhunter
Replied by bountyhunter on topic Valve cover leaks
I use the black ultra high temp gasket maker. You have to apply it right. Clean all surfaces with acetone. Run a thin bead all the way around and just set the cover/gasket on and install the bolts finger tight, JUST tight enough to flatten the sealer out. Wait an hour, and apply a little more pull on the bolts with a socket in your fingers (no wrench) to get the excess sealer out. let cure overnight and torque the cover to about 60 - 70 inch pounds. It will seal it.
The end plugs do have to be installed with gasket sealer. And goes without saying, they have to be level and flush with the head or they will not seal.
Last edit: 08 Sep 2009 19:03 by bountyhunter.
08 Sep 2009 19:06 #320023 by bountyhunter
The oil does pool over the buckets. The oil feeds up through a passage from the crankcase. On my 750, there is a feed passage on each side of the engine going up with orifice restrictors in line to keep pressure up.
08 Sep 2009 19:27 #320031 by Old Man Rock
Oil Paths.... My KZ900, should be approximately the same for yours...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Wile
  • Topic Author
09 Sep 2009 04:28 #320093 by Wile
Replied by Wile on topic Valve cover leaks
DUH I should have realized that.
  • Wile
  • Topic Author
09 Sep 2009 04:29 #320094 by Wile
Just a thought...
I also had to trim the tops down and yes I put a bead around them too.
  • Wile
  • Topic Author
09 Sep 2009 04:37 #320096 by Wile
Maybe I'll try a diferent brand of sealer.
Pounds or ounces?
  • Wile
  • Topic Author
09 Sep 2009 04:41 #320097 by Wile
Great Pic
I don't think my manual has that one, Thanks.
