KZ900
- kawikid
KZ900
05 Sep 2009 08:35
Hi- New KZ900 owner, looking for tips on what to look for to check that the engine is in good condition, and good maintainance regime, bike runs well, cam chain is noisy?
Thanks
Thanks
Kawikid
- timebomb33
Re: KZ900
05 Sep 2009 08:43 - 05 Sep 2009 08:43
if the engine run's well and just makes abit of cam chain noise do a full tune-up on it adjust valve clearances readjust the cam chain tensioner readjust your timing if it has electronic if points ignition clean and regap the points check for pitting on the contacts if any found get new condensers and points or switch to a dyna s electronic ignition also if you have points ignition still set the dwell angle to about 45 degrees they seem to runthe best there. but electronics are way easier set them and forget them last but not least do a proper carb sync and most of your small noises should go away. by the way i got carried away welcome we need pictures
I THINK MY POWERBAND BROKE
Last edit: 05 Sep 2009 08:43 by timebomb33.
- kawikid
Re: KZ900
05 Sep 2009 11:12
Thanks, i will do the tune up as you suggest, i was thinking of switching to electronic ignition anyway, so i will do that at the same time,i adjusted the cam chain but it still sounds a bit noisier than i was expecting, this is my first 4 stroke, as i am a long time Kawi triples guy originaly, so i am not sure what to listen for.
Don't worry about getting carried away, i appreciate all the knowledge, i will upload some pic's later today. I bought the bike from Johnny's Vintage Kawasaki in Ohio last week, had the original pipes put on, it appears to be in original condition so i have a good base to start with.
Kawikid
- Mcdroid
- Gone Kwackers
Re: KZ900
05 Sep 2009 15:05
Welcome Kawikid...if your bike didn't come with a genuine Kawasaki shop manual...buy one...as was mentioned, we love photos.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TerryK
Re: KZ900
05 Sep 2009 15:52
Welcome, and don't worry about members here getting carried away with the information, they will!! lol
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- KZQ
- Administrator
Re: KZ900
05 Sep 2009 19:14
Hi Kid,
My KZ900 will make some cam chain noise when it's too cold to run smoothly. If it quites down once warm everything's fine.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
