kz650 will not idle
- KZ1R1000
Any help would be appreciated.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Old Man Rock
- Thank you received: 225
Naw, I don't bye that...
Cables or petcock is where I'd start looking deeper...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
Timing advancer malfunctioning?
Air leak in carb holder area?
Good Luck!
- KZ1R1000
Thanks just got so frustrated over looked things.
- JMKZHI
- Thank you received: 48
Like 1/4 or 1/2 or something?
- joerider
My problem was the carb spring weakening over time. I hit the hip and spent way too much 40.00 for that stupid spring and it made all the difference in the world.
Also don't pull the petcock off, just pull the line and see if it runs out full or the diameter of the line.
Anywho check the throttle position, I'm sure that is your problem. Mine would start up hit 4 to 5k and I would have to shut it off.
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Let me get this clear. It dies once you turn the choke off right? If so it won't be a sticking throttle cable. Have you checked the idle adjuster?
Idle adjuster... did that on a CB360T. Startled me so bad it slapped the needle all the way around the tach before I could find the kill. :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- KZ1R1000
