- Thank you received: 2
HEAD GASKET QUESTION
- keith1
in head gasket area and no other leaks on motor....i m guessing this little problem is due to the 10.5 to 1 comp........thanks for any input....keith
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- MFolks
- Thank you received: 540
Is the oil leaking around the bolts or next to them?
- keith1
Looking at the shop manual for my 82 GPz1100 B2, the M6 X 1 bolts should be torqued to 87 inch pounds(these are the two small bolts next to the #1 and #4 sparkplugs).
i d have to say leaking at the bolt....what does 87 inch pounds equate to in ft lbs?.....not a hell of a lot i m sure....
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- bigkaw815
- keith1
- davel
the seepage is at the extreme end of the head gasket on both sides right at the small bolts...how close is the closest oil route?......i was thinking of a grade 5 or better and putting a little 1194 on the unthreaded part...
Pretty sure that hole doubles as an oil route. Best to keep any sealant goop away from it. Also, good chance you will strip out the aluminum threads before breaking the bolt so the bolt grade might be irrelevant.
As far as fixing the leak...not sure. I have the same problem but only on one side of the engine. I'm thinking about taking the head off over the winter and changing the head gasket but I don't want to end up with the same result. Someone else will have to chime in with the full-proof solution.
- Thank you received: 2098
Good Luck!
- nads.com
Torque the head again, and get better bolts, and replace to replace the small ones. Those bolts are soft, as are the cam cap bolts and rotor bolt.Likely an unnecessary reminder in this case, but be sure engine is completely cold when re-torquing.
Good Luck!
- Old Man Rock
- Thank you received: 225
If you look directly under those bolt holes, they thread all the way through... Over the last 30 years of installing and removing, the present threads had loosen up a tad...
With a slightly longer bolt (1/8 - 3/16" for example), add a washer & the bolt tip can now secure to new threads...
Just a thought....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
