KZ1000 NEW ENGÄ°NE SMOKES
  • kawastrtfgtr
  • Topic Author
03 Sep 2009 08:53 #318850 by kawastrtfgtr
KZ1000 NEW ENGÄ°NE SMOKES was created by kawastrtfgtr
hi, everyone ı have 1983kz1000j.ı rebuilt engine.clearance from clymer repair book. oversize pistons,new rings, valve jobs, valve seals. but engine smokes and oils first and second cylinders. what ı did wrong? ı just did not change valve guides thats why?but new valve seals? ı did not understand this problem. SOMEBODY HELP ME.......
03 Sep 2009 09:43 #318859 by APE Jay
Replied by APE Jay on topic KZ1000 NEW ENGÄ°NE SMOKES
Sounds like the oil ring expanders are overlapped. Did they have the wires running thru them?
Jay
03 Sep 2009 10:44 #318876 by timebomb33
Replied by timebomb33 on topic KZ1000 NEW ENGÄ°NE SMOKES
does it smoke all the time if it does you may have the scraper rings in upside down also what where your ring end gaps when installed in the cylinder also highly likely what jay has mention could have also happened if it was valve guide related it would smoke abit on start up after sitting for awhile if it is ring related it will smoke alot all the time.
I THINK MY POWERBAND BROKE
03 Sep 2009 15:08 #318920 by PLUMMEN
Replied by PLUMMEN on topic KZ1000 NEW ENGÄ°NE SMOKES
how long has it been run? B)
  • larrycavan
  • Visitor
03 Sep 2009 15:16 #318924 by larrycavan
Replied by larrycavan on topic KZ1000 NEW ENGÄ°NE SMOKES
I agree with Jay.
Check compression. If it's normal or higher than normal, there's a good chance it's the oil ring expaner overlapped.
Oil blowing out the pipe is a pretty good indicator.
03 Sep 2009 20:12 #318978 by TerryK
Replied by TerryK on topic KZ1000 NEW ENGÄ°NE SMOKES
I'd say it was the oil rings, but also could be a head gasket problem. Have a leakdown test done on it and if those 2 cylinders are low, it is possible the head gasket is leaking from an oil gallery.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
05 Sep 2009 17:20 #319314 by Z1R rider
Replied by Z1R rider on topic KZ1000 NEW ENGÄ°NE SMOKES
I had the same problem myself once...the lower oil ring hooked on the lower taper (or lack there of..1103 in stock jugs) and bent the oil ring down along the piston skirt. Only ran the motor for 10 miles and it put a small grove in the jug, I smoothed it out with very fine sandpaper and put in new rings...more carefully this time and all was fine!
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
  • kawastrtfgtr
  • Topic Author
03 Oct 2009 14:03 #325265 by kawastrtfgtr
Replied by kawastrtfgtr on topic KZ1000 NEW ENGÄ°NE SMOKES
Thanks everyone, ı solved the problem.ı did everything right,oil expender rings little bit broken by somebody. Some body what ı did he makes my kz1000 to upset it. and he is not smart he put it on lots of fingerprints and sone little crash signs. ı changed ring set. and he made my clutch upset,damaged it. thats it.ı am just smiling now,what a stupid peopels at my city.
03 Oct 2009 14:51 #325269 by Tommotbird
Replied by Tommotbird on topic KZ1000 NEW ENGÄ°NE SMOKES
Didn't know Borat rode a KZ!!!
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
03 Oct 2009 15:23 #325271 by JamesD
Replied by JamesD on topic KZ1000 NEW ENGÄ°NE SMOKES
I don't get it, somebody sabotaged your engine?? You caught them by fingerprints?? Where do you live? What happened to them?
  • kawastrtfgtr
  • Topic Author
20 Oct 2009 12:29 #328605 by kawastrtfgtr
the most stupid city
  • kawastrtfgtr
  • Topic Author
15 Nov 2009 09:03 #333844 by kawastrtfgtr
Hi,everyone, ı am living in Turkey in ANKARA which is the most stupid city.
THEY saboteded my kz 1000 engine,now thy are doing other bad things to me.they whelling their cars on me, making lots of things.
I rememebered thaT THEY HÄ°T ME THEÄ°R CAR WHEN I HADN'T BEEN Ä°N USA.
THÄ°S CÄ°TY DON'T WANT ME TO RÄ°DE THÄ°S BÄ°KE.
THİS CİTY DON'T WANT ANYBODY TO RİDE MOTORCYCLE.they are also bigotry,nobody rides motorcycle in this city which one is capital one u understant it. what ı am talking abouth.they always plays my bike.yhey are so stupid because they th
ink that ı am not understanding somethings.but ı know every things. if ı don't write to you u understand that he is not alive ok??????????????????????????????????????????????????????????????????????????????????????????????????????????????
thats why to ı wrote this and ı will wrire more to you kz lowers. ı
ı love my bike and all of city hates me and they wants to play me and play my motorcycle, Here is urkey's capital city : ANKARA.
tHANK YOU EVERY ONE,
