I droped a metal spacer down in the motor
- gordwa
02 Sep 2009 13:41 #318616
by gordwa
I droped a metal spacer down in the motor was created by gordwa
Today for about the 5th time i was taking my cams out.Under the cam chain tower is a flat steel looking spacer that hooks to the bottom of the hard rubber cam tower mount.Well it came loose off its rubber base and down into the motor it went.Any thoughts as what my next move is...Thanks:S
- Mark Wing
- Thank you received: 22
02 Sep 2009 13:45 #318621
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic I droped a metal spacer down in the motor
Pull the oil pan and see if it's in the pan if not use a air blower and see if it drops. Welcome to the site too.
Mark
Mark
Yorba Linda Cal.
- Mcdroid
- Gone Kwackers
- Thank you received: 317
02 Sep 2009 13:50 #318628
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic I droped a metal spacer down in the motor
If it doesn't appear in the oil pan, then get a good flashlight and see if you can see it...fish around with a small magnet (cheap at an autoparts store) on a collapsible wand. You should be able to pull it out
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- gordwa
02 Sep 2009 14:16 #318631
by gordwa
Replied by gordwa on topic I droped a metal spacer down in the motor
Ahhhhh the iol pan....I forgot i had one...daaaaa..I rebuilt this motor last year...never could get it to run right.So i just mess with it now and then.But thanks for the help..I will keep you posted how it came out...Gordy
- HerrDeacon
- Thank you received: 1
02 Sep 2009 15:42 #318649
by HerrDeacon
Replied by HerrDeacon on topic I droped a metal spacer down in the motor
I dropped a phillips head bit down in mine when I had the head off last year. Got it out with the collapsible wand that Mcdroid mentioned. Took a little while but it worked. If it never, next step was pan removal.
Best of luck.
Best of luck.
- timebomb33
- Thank you received: 10
02 Sep 2009 16:42 #318659
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic I droped a metal spacer down in the motor
fish around with a magnet or drop the pan. if i have to do that itake the tank off and lay the bike on it's side to do that job
- IowaKZ
- '80 G1 Classic
- Thank you received: 5
02 Sep 2009 18:21 #318700
by IowaKZ
1980 G1 Classic
Bettendorf, Iowa
Replied by IowaKZ on topic I droped a metal spacer down in the motor
Stop, before you drop the oil pan try this:
Try to fish it out with a long magnet. If that does not work, drain out the oil.
then stick your magnet up into the drain hole.
Ideally, you will have a magnet that attracts from the side.
This exact same thing happened to me a couple of weeks ago with the exact same part. I drained the oil out and it was right by the drain hole. I snagged it with the magnet. Saved me dropping the oil pan.
Let us know when you get it out what you did.
1980 G1 Classic
Bettendorf, Iowa
- loudhvx
- Thank you received: 1616
03 Sep 2009 21:58 #318996
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic I droped a metal spacer down in the motor
A friend dropped a cam end-cap down the chain tunnel and we fished it out. This was on a Suzuki 1100, but when I looked down the tunnel with a mirror, it didn't look like there were too many places it could go. The cain acts like two walls, and the cylinders acted like two walls, so it fell onto the crank timing gear and should be easy to get to with a magnet or grabber tool.
1981 KZ550 D1 gpz.
Other links.
- wes_scooter
05 Sep 2009 03:40 #319203
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
Replied by wes_scooter on topic I droped a metal spacer down in the motor
like everyone said try the magnet, my bike had one of those metal plates stuck to the cam chain drive sprocket on the crank. thus the 8 bent valves that i had to replace when i got the bike. good thing you caught that you droped it. if nothing else a pan gasket isent expensive.
76' kz900
70' yamaha R5
2006 wr450f
- roy-b-boy-b
- Thank you received: 103
05 Sep 2009 04:03 #319207
by roy-b-boy-b
Replied by roy-b-boy-b on topic I droped a metal spacer down in the motor
I have done this and have had luck with a magnet. Earlier this year i couldn't fish it out and a friend sprayed carb cleaner in the engine. Oil was holding it on the side and when the sprayed the carb cleaner it fell out on the floor. Roy
