wont run
- krazinite2003
31 Aug 2009 18:08 #318043
by krazinite2003
i have two 1983 kz750 L3
wont run was created by krazinite2003
ok the bike 83 KZ750 L3 now the back round this bike was in boxes i have put it together cleaned carbs 8 times lol lined the tank new air filter bike is stock i had bin riding the bike before i got the air filter and it worked ok put the air filter in adjusted carbs as best as i could by ear i know not good enough noe when i ride for about 20 min i cant keep the bike running
- harm
- Tom
- Thank you received: 13
31 Aug 2009 18:31 #318051
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic wont run
See if it will run longer with the gas cap unlatched. I,m thinking maybe the tank vent is not venting properly.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- MFolks
- Thank you received: 540
31 Aug 2009 18:33 #318052
by MFolks
Replied by MFolks on topic wont run
Good compression? Should have 130 PSI all four cylinders minimum. Spark? Should be a hot blue spark and "Snap" when it fires.
Fuel delivery o.k.? not obstructed by restrictive fuel filter(s).Carb float levels been checked?
Valve clearances been checked lately?
Sparkplug caps and wires been replaced? They age and fail over time.Sparkplugs properly gapped?(.028 to.032)is the range. Correct sparkplugs?
- JR
- Thank you received: 448
31 Aug 2009 18:37 #318054
by JR
Replied by JR on topic wont run
Hi there krazinite2003,
Synching the carbs by ear does not work even for the experts and is apt to do more harm than good. If they are seriously out of whack the bike will want to die after 20 minutes or so. I bought a Morgan Carbtune and like it and if you do a search here you will find many posts from people who built their own carb synch tools.
Are the carbs Mikunis ? Search also here for "bench synch" which would be a good starting point for a full and proper synch using vacuum gauges.
Good luck
Good luck
