Removing valves, what would MacGuyver do?
- Skonnie Boy
30 Aug 2009 15:42 #317652
by Skonnie Boy
'77 kz650C
Removing valves, what would MacGuyver do? was created by Skonnie Boy
So, what's the MacGuyver way of removing valves, without resorting to $150 tools on Z1? I have c-clamps and the like. Someone know of a better, cheaper way? Bonus points if it involves chewing gum or duct tape.
'77 kz650C
- wes_scooter
30 Aug 2009 15:46 #317655
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
Replied by wes_scooter on topic Removing valves, what would MacGuyver do?
if you have a c-clamp large enough take a cheap 3/4" socket and cut out part of it 1-2 flats for a 6pt with a die grinder and cut off wheel. use it to push the spring down and use a magnet to retrieve the keeper. works good.
76' kz900
70' yamaha R5
2006 wr450f
- chance
- Life long biker/
30 Aug 2009 16:03 #317661
by chance
Replied by chance on topic Removing valves, what would MacGuyver do?
Beat it with a mallet..
- stardon
- Thank you received: 5
30 Aug 2009 20:42 #317758
by stardon
Replied by stardon on topic Removing valves, what would MacGuyver do?
Go to local rental store and rent a valve spring compressor.
- fast_johnny
30 Aug 2009 21:09 #317765
by fast_johnny
1977 KZ1000A1 1075cc, Kerker, Cavanaugh Head, RS34s
1995 KZ1000P
Replied by fast_johnny on topic Removing valves, what would MacGuyver do?
If you just want to remove them, the "beat it with a mallet" response is correct. You can take a socket that fits over the valve spring retainer and give it a good whack and as the spring compresses the vibration knocks the retainers loose and Voila! All apart. Just don't lose the retainers as you remove the socket.
Now I haven't figured out how to get 'em back in with a mallet...
1995 KZ1000P
- Skonnie Boy
30 Aug 2009 21:51 #317770
by Skonnie Boy
'77 kz650C
Replied by Skonnie Boy on topic Removing valves, what would MacGuyver do?
Holy shite, I thought the hammer method was a joke. Not that I haven't thought about taking a hammer to my bike just out of frustration...
I have a large c-clamp, though no means to drill or cut a socket bit.
How would I get them back together is the real question now. Just trying to put in new valve stem seals.
'77 kz650C
- roy-b-boy-b
- Thank you received: 103
30 Aug 2009 23:49 - 30 Aug 2009 23:52 #317791
by roy-b-boy-b
Replied by roy-b-boy-b on topic Removing valves, what would MacGuyver do?
Take a piece of pvc pipe and cut a section out to get the retainers out. The pvc should be about 2.5 inches long.
Remove your spark plug and feed small rope into the piston that is half way up on the compression stroke. Compress rope with piston.
When you are done back the engine up with the 17mm bolt on the ignition side.
Last edit: 30 Aug 2009 23:52 by roy-b-boy-b.
- Skonnie Boy
31 Aug 2009 07:55 #317868
by Skonnie Boy
'77 kz650C
Thanks for the tip. I will try a combination of all these techniques and report back as far as how badly I screw things up/ triumphantly replace my valve stem seals.
'77 kz650C
- Skonnie Boy
31 Aug 2009 15:18 #317990
by Skonnie Boy
'77 kz650C
Got some PVC pipe, cut it and cut out a section. One last question: As far as using the c-clamp, is it safe to brace it against the valve? Seems like it could easily bend the flanges on the pipe. Maybe use something small and pointy to brace it against the inner part of the valve, i.e. the bottom of the cone?
Just crossing T's and dotting I's here.
'77 kz650C
- chance
- Life long biker/
31 Aug 2009 15:56 #318003
by chance
Dude rent or buy a valve spring compressor. Save yourself time and trouble they are cheap. If you use that c clamp and bend or break something that will cost you big. Also you can take a paper clip some gum and duct tape mix charcol saltpeter. and blow the keepers off....
- donthekawguy
- Thank you received: 8
31 Aug 2009 23:49 - 31 Aug 2009 23:51 #318148
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Removing valves, what would MacGuyver do?
I got a cheapo spark plug socket and cut about a third of the side out. I use a wood clamp to tighten it down. Works like a charm. No need to buy or rent the "right" tool when you can make your own for about $5. I have used it 10 times or so without a problem.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 31 Aug 2009 23:51 by donthekawguy.
- Skonnie Boy
01 Sep 2009 12:05 #318260
by Skonnie Boy
'77 kz650C
This might help a bit. Personally, unless I see a picture, its all Chinese algebra to me.
1st, pic, you can see I cut out a section of white PVC pipe and cut slats in it to access the retainer. In the 2nd picture you'll see I cut out a wood wedge section to brace the inside of the valve bottom. My thinking was that if I used the flat end of the c-clamp against the outer flanged ends of the valve, they might bend. Does this sound about right? Or do I brace the end of the c-clamp against something other than the valve itself?
Thanks for all the responses.
'77 kz650C
