Crankshafts and Kickstarts
- Yojymbo!
30 Aug 2009 12:40 #317617
by Yojymbo!
Crankshafts and Kickstarts was created by Yojymbo!
I can get a free spectre 750 engine with few miles(shaft drive but otherwise same as GPZ).
Would it be worth the trouble to drop the crank from the spectre into a 78 KZ lower and use the Spectres upper casing to accomodate 750 jugs for an 810 build?
I figure it would be cheaper to keep use the upper casing from the spectre than have the KZ bored over, plus the crank uses a modern cam chain (I believe), has GPZ oil holes to oil the pistons, and better rods. Will it fit the journals of the KZ 650. Just replace the chain and drop in? I really want to keep the kick start, hence not just buying a newer engine.
- hoghaterkaw
- Thank you received: 1
30 Aug 2009 15:08 #317646
by hoghaterkaw
Replied by hoghaterkaw on topic Crankshafts and Kickstarts
Vi
no because the two case halves are machined as a pair for all the shafts.
- Yojymbo!
30 Aug 2009 15:43 #317654
by Yojymbo!
Replied by Yojymbo! on topic Crankshafts and KickstartsVi
Thanks!
