new engine gaskets
  • Darkangel
  • Darkangel's Avatar Topic Author
new engine gaskets
28 Aug 2009 21:17
#317204
What all is required if I want to replace all the eninges gaskets on my kz. Do you have to do timing all over again.
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • bountyhunter
  • bountyhunter's Avatar
Re: new engine gaskets
28 Aug 2009 21:54
#317214
I don't understand the question. You want to replace every gasket in your engine?
  • TerryK
  • TerryK's Avatar
28 Aug 2009 21:55
#317215
Depends on what gaskets you are replacing.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Darkangel
28 Aug 2009 22:00
#317216
All the top end gaskets....
  • TerryK
  • TerryK's Avatar
28 Aug 2009 22:03
#317218
Then obviously, yes. Why are you changing them?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • Darkangel
28 Aug 2009 22:10
#317220
because they are all old as crap...I have oil that seeps threw them...and causes the engine to smoke alote...plus hot oil doesn't feel to good on your bare legs...
  • TerryK
  • TerryK's Avatar
28 Aug 2009 22:24 - 28 Aug 2009 22:25
#317224
I would suggest starting with the cam cover gasket, then see if you still have leaks......wait.....bare legs???? :ohmy:
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 28 Aug 2009 22:25 by TerryK.
  • Darkangel
28 Aug 2009 22:26
#317225
yea something I almost never do....Ride in shorts.:blush:
  • Darkangel
28 Aug 2009 22:45
#317230
i know it's leaking at the valve cover, buts also leaking by the timing chain tensioner, and around that section of the block.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Aug 2009 02:16
#317234
To answer your question...yes. Here is the required gasket set www.z1enterprises.com/detail.aspx?ID=1735
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • PLUMMEN
  • PLUMMEN's Avatar
29 Aug 2009 04:53
#317241
try tightening things up first B)
