Ring Compressors?
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar Topic Author
Ring Compressors?
16 Mar 2006 10:19
#31693
Cause I'm very cheap, I wanted to come up with something (cheap) that would compress my piston rings, for easier insertion into the cylinders. Just made two. Haven't tried them yet but what do you think?
I took a 2" PVC pipe straight coupler/joint and sliced it across the middle so I now have 2 PVC "rings/hoops" about 1" long and 2.5" dia. Then I cut a gap in each so that it could be "sprung" open. The 1/8" saw gap can be opened to about 3/4" without breaking the PVC. Now I've chamfered the top edge at 45 degrees all the way around.
I will slip the PVC "ring" under the piston, spring it open then raise it to cover the piston rings.
Wadaya thank?
  • securitygeek
  • securitygeek's Avatar
Re: Ring Compressors?
16 Mar 2006 10:22
#31695
how about a large hose clamp, with a thin peice of cardboard (like from a cereal box, between the clamp and piston, to protect from scratches. It worked for me.
  • BARNEYHYPHEN
16 Mar 2006 10:35
#31706
Hey SG, I started along those same lines but I was going to use a piece of 3" dia PVC pipe and pull it closed with a large hose clamp (Jubilee clip). Then I got the idea to use a smaller dia pipe and let the natural spring tendency of the pipe do the work. Saves me spending $3 on two hose clamps and I get away with spending only $1.
The 2" joint piece is about 2.5" dia in it's natural state.
  • securitygeek
16 Mar 2006 10:38
#31708
That would work, as long as there is enough tension in the pipe, without breaking when you take it off.
  • rammy
  • rammy's Avatar
16 Mar 2006 13:11
#31739
wide electrical zip ties work too just dont run them down to tight so they slide on the piston
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • Z1109R Fin
  • Z1109R Fin's Avatar
17 Mar 2006 05:23
#31903
Fingertips have worked fine twice...almost...
Z1000R ´83...Slightly modified...
  • wiredgeorge
  • wiredgeorge's Avatar
17 Mar 2006 06:47
#31915
Fingertips have worked for many, many sets of rings. I DO find that the two homemade braces I made for holding the con rods of two pistons is a big help. I slide these under the two pistons (2&3) I first set the block on and it helps keep them located upright. I set the block gently on the top rings and compress one piston's top rings until the cylinder sleeve drops over and will hold that ring. The cylinder is SLIGHTLY tilted, I guess. Then I do the same for the other piston. I repeat this process till I have the cylinder sleeves compressing all three rings for the 2 & 3 pistons. Then I remove the wood blocks and rotate the crank by pushing down on the cylinder a bit and do the same for 1 & 4 pistons. I do have ring compressors but don't use them. There isn't much room to work with them and I find this method easier. It just requires some patience as you do get the urge to SHOVE DOWN on the cylinder to get it over the rings...
  • BARNEYHYPHEN
17 Mar 2006 08:17
#31941
Photo of 1st attempt at the PVC ring compressor. Tried it last night on a spare piston/rings and certainly seems to work.
  • patmann
  • patmann's Avatar
17 Mar 2006 11:19
#31985
PATIENT IT !!!!!!!!!!!! Then sell it to Harbor Freight:lol:
Sure looks like it would work.
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • BARNEYHYPHEN
17 Mar 2006 13:10
#32003
Hey Patmann, probably should have done that yesterday! I could have probably made it onto "American Inventor" (except I'm Ingrish).
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
17 Mar 2006 13:32
#32007
Looks good. Will have a try with some here.
  • APE Jay
  • APE Jay's Avatar
17 Mar 2006 16:43
#32051
Popcicle sticks were invented for installing piston rings:P
Jay
