1981 kz 1000J SHIFT SHAFT
- john8
- Anything unrelated to elephants is irrelephant
27 Aug 2009 16:41 #316808
by john8
I want to ride my bicycle!!!
1981 kz 1000J SHIFT SHAFT was created by john8
Can someone please direct me to a diagram for the shift lever and shift shaft that displays all of the seals and part numbers to order from a kawi dealer. The only specs I have found do not have the seals listed.
- roy-b-boy-b
- Thank you received: 103
27 Aug 2009 16:58 #316812
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1981 kz 1000J SHIFT SHAFT
Did you try bikebandit.com ?
- john8
27 Aug 2009 17:40 #316829
by john8
Replied by john8 on topic 1981 kz 1000J SHIFT SHAFT
Yes. No good,no seals.
- john8
27 Aug 2009 17:44 #316831
by john8
I need something that gives me a diagram including the cluch push rod seal the main output seal or the counter srrocket and so on. I can't seem to find it anywhere.
- Thank you received: 2235
27 Aug 2009 20:57 #316884
by TexasKZ
Replied by TexasKZ on topic 1981 kz 1000J SHIFT SHAFT
- PLUMMEN
- Thank you received: 104
27 Aug 2009 21:52 #316906
by PLUMMEN
Replied by PLUMMEN on topic 1981 kz 1000J SHIFT SHAFT
id call jeff at z1 enterprises i dont see it listed in the gasket set but that doesnt mean he doesnt have them
- john8
29 Aug 2009 17:55 #317434
by john8
Thank's. Found it through Z1.
