- Thank you received: 8
Clutch Pushrod Seal?
- gvsu141
26 Aug 2009 18:17 #316611
by gvsu141
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
Clutch Pushrod Seal? was created by gvsu141
Does anyone know where i can buy just the pushrod seal? z1 enterprises has the whole kit but all i need is the one seal.
2001 ZRX 1200
1973 z1 900
- gvsu141
26 Aug 2009 18:22 #316612
by gvsu141
2001 ZRX 1200
1973 z1 900
Replied by gvsu141 on topic Clutch Pushrod Seal?
its a 1980 kz1000 ltd by the way
2001 ZRX 1200
1973 z1 900
- arai59
- Banned
- Thank you received: 1
26 Aug 2009 18:24 #316614
by arai59
Replied by arai59 on topic Clutch Pushrod Seal?
Look for a bearing seal distributor in your area. Most seals are standard and are easy to buy. They are measured by ID, OD and depth or thickness of seal.
www.timken.com/en-us/Pages/Home.aspx
- mzandmz
26 Aug 2009 19:16 #316628
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Clutch Pushrod Seal?
Did you try powersedge.com ?
- Thank you received: 2829
27 Aug 2009 18:39 #316846
by 650ed
Replied by 650ed on topic Clutch Pushrod Seal?
What is the part number for the seal? I see a 7mm O-ring (part #670B1507 - still available) that the rod passes through, but I cannot figure out which seal is needed. Ed
