Transmission Issues
- sramsey216
Transmission Issues
25 Aug 2009 09:38
My transmission no longer shifts into gear properly. When upshifting the shift lever remains in the "up" position and doesn't "snap" back down to engage the next gear. I have to manually reset the position of the shifter by doing a sort of half of a down shift. Same thing happens on the downshift, I have to do half an upshift (gently positioning the lever in the right position).
Is there a spring or mechanism that forces the shift lever into the proper position after a shift that might be broken or disconnected?
I also can't shift into neutral.
Thanks in advance.
-Scott
Thanks in advance.
-Scott
1980 KZ1000 LTD
- sramsey216
- keith1
Re: Transmission Issues
26 Aug 2009 15:28
Two common causes are -
1. Broken or dislodged return spring. Yes, there is one.
2. Serious build-up of grunge on the shifter shaft where it goes through the sprocket cover.
- PLUMMEN
26 Aug 2009 15:52
pop off your countershaft sprocket cover and chain and sprocket then pull off the trap door and check the springs and linkage.drain the oil before removing the trap door and make sure you buy a new gasket,this is one of those places where you definately want a gasket
- sramsey216
26 Aug 2009 16:43
Thanks Plummen, your expert advice is always appreciated. Here is the dirty little culprit. Now bonus points for the part number
1980 KZ1000 LTD
27 Aug 2009 21:51
92083-028 SPRING,CHG PEDL RTRN
