Cam chain tensioner - again
- markc3wa
24 Aug 2009 20:51 #316222
by markc3wa
Cam chain tensioner - again was created by markc3wa
I discovered while adjusting the valves on my kz650D1 that the cam chain tensioner was bad. I found an identical replacement at a reasonable price that appears to work as it should (the bolt can be removed, the tensioner's rod moves freely in and out of the bore it's in) at the local boneyard. I've re-shimmed under the buckets, re-installed the camshafts as per my Clymer's and installed the tensioner. It doesn't appear to be doing much of anything; when I rotate the engine via the 17mm nut on the ignition advancer, the cams turn, the chain tightens and then .. slap .. all the tension leaves the chain and the engine lurches forward. I'm pretty sure that it's the tensioner that's not doing its job although I will be re-re-re-checking the camshaft installation to make sure I did that right. Any advice on how to install a stock replacement tensioner? Thanks.
- PLUMMEN
- Thank you received: 104
24 Aug 2009 20:59 #316226
by PLUMMEN
Replied by PLUMMEN on topic Cam chain tensioner - again
have you got access to a shop manual?
- markc3wa
24 Aug 2009 21:19 #316231
by markc3wa
Replied by markc3wa on topic Cam chain tensioner - again
I've got a Clymer's but it's not been helpful with this or even some other items (like removing the tach pinion). I'm hoping for some "real world" advice.
- TerryK
- Thank you received: 3
24 Aug 2009 21:48 #316239
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Cam chain tensioner - again
This is a really dumb question I know, but are sure you are not turning the engine backwards??
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- markc3wa
25 Aug 2009 06:06 #316279
by markc3wa
The book says to turn the nut clockwise and that's what I've been doing.
- RonKZ650
- Thank you received: 240
25 Aug 2009 06:50 #316284
by RonKZ650
Replied by RonKZ650 on topic Cam chain tensioner - again
You are tightening the lock bolt on the tensioner before attempting to turn the engine over I hope? These tensioners don't cause any trouble generally, but if you turn the engine over with the bolt loose there will be problems.
Another tip about the tach pinion. Leave it be, no need to remove it unless it's leaking.
