Ignition
- rayellis
22 Aug 2009 20:06 #315841
by rayellis
Ignition was created by rayellis
I have a kz750 and was seeing somethings about a GM HEI ignition module. What is it exactly and would it replace the KZ750's ignition?What else is out there that can replace or upgrade the ignition?
Thank You
Thank You
- mzandmz
22 Aug 2009 20:16 - 22 Aug 2009 20:17 #315844
by mzandmz
Last edit: 22 Aug 2009 20:17 by mzandmz.
- mzandmz
22 Aug 2009 20:18 #315845
by mzandmz
- MFolks
- Thank you received: 540
22 Aug 2009 20:24 #315847
by MFolks
Replied by MFolks on topic Ignition
As long as your pick up coils are in good shape and your bike has the mechanical ignition advancer, you could do this if the factory system ever died.The Dyna "S" works but is considered a power hog compared to what Kawasaki installed.
www.geocities.com/loudgpz/GPZgmHEImod.html
- JR
- Thank you received: 448
24 Aug 2009 06:58 #316089
by JR
Replied by JR on topic Ignition
The GM HEI thingy would replace your ignitor ...if it was bust and needed replacement. If your current ignition system is working then I would suggest that the best and cheapest (about $10) upgrade would be to do the coil repowering mod.
