Hanging idle--fast idle--Ect....
- gremmie7
20 Aug 2009 15:55 #315324
by gremmie7
First off, this is a great and very helpful site.
That said, I am having a heck of a time with
my 1983 Kaw Spectre 1100 D2.
History:
Bike sat for 5-6 years.
Has a mac pipe and a dyna jet kit.
Jets are #120/#35 Clip is on 2nd from top.
Carbs have been cleaned and checked several times.
( I can't sleep at night until I disassemble/reassemble carbs)
All vacuum lines have been replaced, clean air system removed, block offs in place, new vacuum plugs on 1,3,4.
New orings in carbs, new carb manifolds, new fuel line, tank was cleaned and sealed. Petcock in good working order.
Fuel/air screw 1.5 turns out.
Spark advance cleaned and lubed, checked visually to be working.
Slides working properly, started with air box(stock) removed
and they return quickly.
New throttle cable, lubed, snaps right back.
Problem:
With choke on bike revs out of control up to 5000rpms,
push in choke and it idles at 1000rpms. If you rev it up with the throttle from there, the idle hangs and comes down slowly, but over 4000rpms, won't come down.
There are no vacuum leaks, I have checked with wd-40, carb cleaner, starter fluid and water.
Any help would be great and thanks again for such a great site.
1977 XT500D
2000 Kawasaki Concours
1985 Honda Nighthawk 750
1983 Kawasaki Spectre 1100
Hanging idle--fast idle--Ect.... was created by gremmie7
History:
Problem:
1977 XT500D
- Thank you received: 2098
20 Aug 2009 17:09 - 20 Aug 2009 17:11 #315341
by Patton
Replied by Patton on topic Hanging idle--fast idle--Ect....
Most of the usual causes seem to have been already ruled out.
Random thoughts --
Are the pilot air screw plugs in place?
Do the choke plunger tips have pads to supposedly seal off choke function when the choke is off?
Good Luck!
Random thoughts --
Good Luck!
Last edit: 20 Aug 2009 17:11 by Patton.
- gremmie7
20 Aug 2009 17:18 #315343
by gremmie7
1977 XT500D
Replied by gremmie7 on topic Hanging idle--fast idle--Ect....
The choke plungers are:blink: working.
I replaced the pilot plug orings, but I think I got the wrong size. I do not feel they were snug enough. I have ordered new ones, I have a feeling this is the issue.
Of course I have had this feeling about a few other things that were causing the problem.
1977 XT500D
- Beatpoet
20 Aug 2009 17:47 #315367
by Beatpoet
Replied by Beatpoet on topic Hanging idle--fast idle--Ect....
Sounds lean...
1) Intake/exhaust manifold leaks.
2) Timing jittery? bad points/condenser/advancer?
3) sticky floats?
Check vacuum on a manometer while revving.
3) sticky floats?
- larrycavan
- Visitor
20 Aug 2009 18:00 #315369
by larrycavan
Replied by larrycavan on topic Hanging idle--fast idle--Ect....
Something tells me there's a lot more to this story that led to this
Has anyone messed with the synch adjusters?
I've seen carbs rev like that when the synch adjusters are all out of wack. Usually happens when one carb was way off from the others and someone cranked the synch adjuster a bunch of turns.....
- gremmie7
28 Aug 2009 21:33 - 28 Aug 2009 21:36 #317210
by gremmie7
1977 XT500D
:laugh: :laugh:
Rode it to work today!!
I love parking my metrics in the service lobby of an H-D dealership.
Got the check valve o-rings yesterday, bike no longer hangs at 5k. Drops good until 3500rpm then slow until 1000rpm.
Going to synch on sunday.
Still running rich.
should I change the pilot to a #37.5?
and the main to #117.5?
Thanks for the help.
Still running rich.
1977 XT500D
Last edit: 28 Aug 2009 21:36 by gremmie7.
- roy-b-boy-b
- Thank you received: 103
29 Aug 2009 04:59 #317243
by roy-b-boy-b
Replied by roy-b-boy-b on topic Hanging idle--fast idle--Ect....
What kind of carbs are you running? Roy
- gremmie7
29 Aug 2009 10:27 #317324
by gremmie7
1977 XT500D
Stock 34MM with dyno jet kit, stock air cleaner, very non-restricted mac pipe.
1977 XT500D
- roy-b-boy-b
29 Aug 2009 10:36 #317329
by roy-b-boy-b
The mains seem small to me. I'm running 122.5 in my 28mm carbs.I was running 140's in my 34mm with the cams and 1075 kit.
Have you checked your valve clearance lately?
Just offering suggestions. Roy
