Putting in rings on 81 KZ750 LTD
- Johnny Red
- 80 KZ750 H LTD
17 Aug 2009 12:49 #314607
by Johnny Red
Putting in rings on 81 KZ750 LTD was created by Johnny Red
How do you place the piston rings in correctly?
- bountyhunter
- Thank you received: 337
17 Aug 2009 13:38 #314614
by bountyhunter
Replied by bountyhunter on topic Putting in rings on 81 KZ750 LTD
I recall on my twin, the gaps on the top and bottom ring go forward and the middle ring gap goes to the rear.
- Nebr_Rex
- Thank you received: 300
17 Aug 2009 16:05 #314636
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Putting in rings on 81 KZ750 LTD
I place the oil rings at 120 degrees and the compression rings over the wrist pins at 180 degrees.The rings will rotate on the piston
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Thank you received: 2829
17 Aug 2009 18:23 #314662
by 650ed
Replied by 650ed on topic Putting in rings on 81 KZ750 LTD
The Kawasaki factory service manual describes this in detail. You probably shouldn't plan to rebuild the engine without the manual as it contains other information (torque specs, service limits, head bolt tightening sequence, etc.) you will need. The manuals are nearly always for sale on eBay; just be sure to get the one for your specific model/year. Ed
- bountyhunter
17 Aug 2009 21:38 - 17 Aug 2009 21:39 #314690
by bountyhunter
Nebr_Rex wrote:
I don't think they are supposed to move after they are installed. I took the factory pistons out of mine after 75,000 miles and they were still exactly aligned per spec: top and bottom dead front, middle straight back. I don't think they move in service.The rings will rotate on the piston
Last edit: 17 Aug 2009 21:39 by bountyhunter.
