Exhaust Stud Removal Help
- XL777
16 Aug 2009 19:54 #314468
by XL777
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
Exhaust Stud Removal Help was created by XL777
I have a stripped exhaust stud that needs to be replaced. I ordered a new one from Z1 but I can't get the old one out. Any tips? Its too stripped to double nut and torque off and I don't have a welder to tac a nut on. Any other tips?
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- mzandmz
16 Aug 2009 20:04 #314470
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Exhaust Stud Removal Help
Can you get visegrips on it? Do you have a propane torch.I would apply some heat to the bolt. Steel heats differently then aluminum causeing expansion that will help in extracting your bolt, using visegrips.
- XL777
16 Aug 2009 20:05 #314472
by XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
Replied by XL777 on topic Exhaust Stud Removal Help
Yes I can get grips on it but I don't have a torch
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- KZ250LTD
- Thank you received: 16
16 Aug 2009 20:07 - 16 Aug 2009 20:10 #314473
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic Exhaust Stud Removal Help
Buy yourself a stud remover from any automotive store. Should be cheap, >$10, hooks onto a regular 1/2' or 3/8' drive ratchet and gets a grip on the stud and loosens it using the torque of the ratchet.
Should look like this
79 KZ1000ST
Past:
Many.
Last edit: 16 Aug 2009 20:10 by KZ250LTD.
- Thank you received: 2829
16 Aug 2009 20:15 #314476
by 650ed
Replied by 650ed on topic Exhaust Stud Removal Help
Soak the stud with Kroil for 2 or 3 days and it should unscrew with no difficulty. I have used Kroil on stuck nuts & bolts with amazing results. Ed
- mzandmz
16 Aug 2009 20:17 #314478
by mzandmz
can you tap on the end of the bolt. It helps to hammer on it a few times.
- mzandmz
16 Aug 2009 20:26 #314481
by mzandmz
PB blaster or what ever its calded like liquid wrench stuff. only better helps a lot. Spray it, hammer on it, try turning,hammer, turn, spray, hammer, turn , something like that
- XL777
18 Aug 2009 17:34 #314900
by XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
Got some PB and a 8mm socket with some teeth and out it came. Thanks again guys.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
