HELP..oiled spark plug
- kawastrtfgtr
- mzandmz
New to Family, 1979 KZ440 LTD
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Thank you received: 2098
Hi,everyone.my KZ1000J has a problem.it had oiled 2. spark plug generally.And ı rebuilt all the engine but my same problem goes on... it starts good then warm the engine smokes and second spark plug oils,and second exhaust pipe cold.ı looked the cylinder head,valve rubbers.all okey.the ring sets in cylinder 0.45mm gap.i couldn't find this problem.does any one knows this problem.HELP.
Maybe #2 oil ring is damaged. :pinch:
Good Luck!
- kawastrtfgtr
- kawsakiman
- Thank you received: 6
did you use oversized pistons or just ball hone the cylinders and install new rings?
you did use new rings right?
i would do a leakdown test @ tdc then @ bdc.
i'm suspecting cylinder wall taper here.
- kawastrtfgtr
- kz1100warrior
- Thank you received: 1
When my mechanic had put in the new rings (so called Mechanic will never use again) the expander ring was broken by the clip where the the two ends meet.so the ring was sliding by each other instead of closing together. The only reason I had found this out because of the oil and smoke. I then myself refitted new rings on 2 piston and working perfectly.The only way to check is redo i am afraid.
Good luck
- kawastrtfgtr
- kawastrtfgtr
