- Thank you received: 3
The way to take clutch hub off from clutch housing
- tybolt99
- From where KZs came
15 Aug 2009 18:51 #314230
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
The way to take clutch hub off from clutch housing was created by tybolt99
It is about 76 kz900 I got about 7 weeks ago.
Trying to take clutch hub off from housing without kaw's clutch hub holder special tool. Tried to remove 30mm nut with 1/2 socket with pipe while holding hub with handle welded steel clutch plate, impact wrench etc but didn't come off. Supposes to be tighten with 87-108 ft-lbs but it got to be more than that.
The reason I need to remove hub is I found one of five spring plate bolt is broken when I opened to change clutch plates and cannot back it out. Looks like someone tried to back it out and left broken screw extractor in it. I got another hub to replace with.
Any one knows a trick?
Thank you in advance.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- mzandmz
15 Aug 2009 19:19 #314234
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic The way to take clutch hub off from clutch housing
BOY do I I made my own. Flat 1/2 plywood about 8inches by 20 inches. near the end drilled 5 holes where bolts go through and a big hole in center for the socket. I will post a scary drawing below .
- mzandmz
15 Aug 2009 19:30 #314235
by mzandmz
Blue line is where you bolt it to the bolt holes that the springs go. and the orange is where you use a socket extention and ratchet to remove nut. the board being long helps to hold the clutch housing from turning. I had to buy longer bolts to bolt the plywood to the five, In your case the four remaining holes. Was slick, But I had the engine out of the frame so I dont know if you have the room.
- TerryK
15 Aug 2009 19:34 #314238
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic The way to take clutch hub off from clutch housing
Dumb question but did you bend over the tab on the locking washer? An impact gun should spin that right off.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- mzandmz
15 Aug 2009 19:40 - 15 Aug 2009 19:40 #314241
by mzandmz
Mine is a KZ650 I didnt have a bent over lock washer, Mine has a Spring washer, looks concaved and when compressed or tightend it locks itself under pressure
Last edit: 15 Aug 2009 19:40 by mzandmz.
- tybolt99
15 Aug 2009 19:45 #314244
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Replied by tybolt99 on topic The way to take clutch hub off from clutch housing
Thank you mzandmz. that may work if I don't make it to wide and let it shit against footrest.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- tybolt99
15 Aug 2009 19:52 #314247
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
I am pretty sure just a flat washer under the nut.
Manual says,
"Take out a few clutch plates, hold the clutch hub from turning using a special tool, and remove the mounting nut."
Not mention about locking washer.
Sounds easy. I swear the nut has been tighten real tight like 200 ft lbs!
Manual says,
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- mzandmz
15 Aug 2009 20:08 #314248
by mzandmz
I got impaitiant on mine and broke off a finger of the basket. I tried a big crow bar between the fingers againts the center hub .ooops. Took it down and had it welded for $15.00 so no big deal a new cluch housing is spppencive.
