engine pinging
- roadsoul
15 Aug 2009 13:08 #314083
by roadsoul
1982 KZ1000 P1 23000 Mi.it was in police service for 22 yrs.I think it
spent most its life parked.It has some battle scars but is corrosion free and spotless.It was decommisioned
with 14000 Mi. What a sweet ride!!
engine pinging was created by roadsoul
Hey Guys,My 82 kz1000p runs good when it warms up but
after 8 to 10 miles it pings when you roll on the throttle
Im using 87 octane fuel.Could it be timing or valve
clearance issue?The timing advance is clean and lubed.new
plugs and caps,did a dark test on plug wires they are
ok.its been about 6000mi.since it had a major service.
(all topend gaskets,valves adjusted,new cam tension springs,
carbs rebuilt,new holders,oil and filter change)I did a
search but didnt find anything.Any info would be greatly
appeciated! Will post a pic soon. Thanks, Roadsoul
- mzandmz
15 Aug 2009 13:14 #314084
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic engine pinging
Did you check your spark plugs? Are they burning good,Not carboned. If a Bike runs a little on the lean side more heat is built up causing pre-detination or ping. A cooler plug might help. You'll get more help in a minute.
- MFolks
- Thank you received: 540
15 Aug 2009 13:18 #314086
by MFolks
Replied by MFolks on topic engine pinging
I'd suggest trying a set of NGK B9ES (colder sparkplug) gapped between 0.028 to 0.032 and see how it runs.
- bountyhunter
- Thank you received: 337
15 Aug 2009 14:18 #314097
by bountyhunter
Replied by bountyhunter on topic engine pinging
I recommend you get a timing light and see if your timing is correct from idle up to 4k RPM. The FSM has the timing advancer curve and I will wager an old advancer is not following it very well. Anyway, mine was way off.
As for pinging, I would try better gas. My 750 never ran right on 87 so I don't feed it that.
Ditto on looking at the plugs to see if they are running too hot.
- Thank you received: 2829
15 Aug 2009 18:53 #314231
by 650ed
Replied by 650ed on topic engine pinging
Try 93 octane to see if it still pings. Premium fuel is much cheaper than replacing pistons. Ed
- TerryK
15 Aug 2009 19:19 #314233
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic engine pinging
92 or 93 octane is barely high enough for engines built to run on 100+. Use the highest you can find and you should be good. Also as someone else suggested, check the timing.
My 77 1075cc, 10.25 compression kz1000 pings on hot days with 93 octane in it. I can't imagine what would happen if I ran 87.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Thank you received: 2098
16 Aug 2009 03:11 #314271
by Patton
Replied by Patton on topic engine pinging
If the advancer is the style in pic below, the F mark at idle rpm should align with the permanent case mark when viewed under a timing light.
Excessive carbon deposits in the combustion chamber might raise compression psi too high. If not already done, could perform a compression test to help determine whether there might be excessive compression.
As noted, NGKB9ES sparkplug is indeed one step cooler than the standard NGKB8ES. However, the reported history doesn't mention plug brand or heat range. So would first assure that NGKB8ES -- the correct sparkplug -- is installed before further diagnosing cause of the pinging.
Good Luck!
{Click on image to enhance view]
Good Luck!
- timebomb33
- Thank you received: 10
17 Aug 2009 03:57 #314528
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic engine pinging
you answered the question yourself you should be running as high an octane fuel as you can buy with out resorting to something like e-8590+ octane if at all possible in the heat of the summer air cooled motors have enough problems with out dealing with low quality fuels.
- hoghaterkaw
17 Aug 2009 06:17 #314550
by hoghaterkaw
Replied by hoghaterkaw on topic engine pinging
If the bike is stock, 87 octane is what it was designed to run on. If you installed new fuel line make sure there are no kinks. Also some inline gas filters can slow the fuel flow.
- roadsoul
17 Aug 2009 08:01 #314569
by roadsoul
Replied by roadsoul on topic engine pinging
Hey Guys,I replaced the fuel filter and checked the spark
plugs.no.1-rich,no.2-good,no.3-lean,no.4-good.Ive tried
all three grades of fuel,it seems to do best with 89 octane.
I tweaked the carbs, it runs good but still pinging but not
as bad.Im gonna borrow or buy a timing light this week and
check the timing,Im convinced thats the problem.I still
need valve clearance checked and adjusted if needed and
check head torque.If anybody knows a good kz mechanic in the
Houston area please let me know.A special thanks to all with
their great responses, I truly appreciate it.Ill keep you
guys posted what I find out. Thanks again, Roadsoul
- mzandmz
17 Aug 2009 08:18 #314571
by mzandmz
Whens the last time you had your carbs sync'ed.?
- roadsoul
17 Aug 2009 09:53 #314585
by roadsoul
The carbs were synced when they were rebuilt less than
2 yrs ago.But I forgot to mention that I noticed carbon build up on the top of the pistons when I checked the plugs.A guy told
me about a product called ring free from yamaha that will
safely remove carbon from the top end.All the bike shops
are closed on mondays around here so Ill hit the yammy
dealer tommorow and check it out. Thanks,Roadsoul
