Timing alignment help needed
- KAWAMIKIE
13 Aug 2009 20:33 #313794
by KAWAMIKIE
81 KZ1000 LTD
08 ZX14 Ninja
Timing alignment help needed was created by KAWAMIKIE
I got a shim and tappet for my bike now I need to confirm the cam timing is correct. It's on my 1981 KZ1000 LTD.
I searched but came up empty, only found it for earlier models.
If you could provide a link to it or post the info I'd appreciate it.
81 KZ1000 LTD
08 ZX14 Ninja
- Kawickrice
- Thank you received: 18
14 Aug 2009 11:28 #313900
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Timing alignment help needed
Not sure about your bike but I would do a search for a downloadable MANUAL for your model. There was a few threads that had mega manuals.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bowtie39
14 Aug 2009 15:52 #313932
by bowtie39
Replied by bowtie39 on topic Timing alignment help needed
I'll be watching as this is what I need to know also. Where did you get the parts?
Roger
Roger
- KAWAMIKIE
14 Aug 2009 18:20 #313972
by KAWAMIKIE
81 KZ1000 LTD
08 ZX14 Ninja
Replied by KAWAMIKIE on topic Timing alignment help needed
bowtie39 wrote:
Look at this thread for info on a shop manual download. It clearly shows how to set the timing.
kzrider.com/index.php?option=com_kunena&...w&catid=10&id=313522
I got the shim from my local Kawi dealer. I got a 2.65, that's what the broken one measured. I was able to clean up my existing tappet. This is just a temporary fix. I want to get the bike running and ride it to check how the trans works. Then I'll tear the engine down for rebuild and mods.I'll be watching as this is what I need to know also. Where did you get the parts?
Roger
81 KZ1000 LTD
08 ZX14 Ninja
- Buda
14 Aug 2009 18:56 #313982
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic Timing alignment help needed
One thing that I didnt notice when I was doing the cam
timing is that manual says 44 pins with the pin the ex arrow is pointing at being 0.
Also the torque spec for the cam cap bolts is to high. Be carefull they strip real easy.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
