- Thank you received: 1
Damn this is not good! My bike took a sh**t!
- 550A2
- keep the shiny side up
I got it in my shop shut it off and tried to start it again, it barley starts! but once it started it ran like shit.
I checked it for spark and im good there, but i need to do a comprression test. I think its a problem with the carbs. But it just suddenly appeared so i dont know what it could be.
ALSO: when i pulled it in my shop it smelt really rich like gas.
This is my only transportation to college and back and i need it! i dont know what to do
someone please help!
its an 82 Kz550 A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- MFolks
- Thank you received: 540
- 550A2
Sence gas started pouring out of the overflow tubes i figured the floats might have got stuck.
and sure egnough i drained them and found a little water too.
But After draining them and starting it it ran fine.
I am gonna use a fuel filter now so this dont happen again.
thank god it isnt an engine problem, which it seemed like.
I run 92 octane cause thats what it sayt to run in the service manual.
But thanks guys, this site kicks ass!
srry fir the misclassification of this post.
- rpiian
- Live to Ride, Ride to Live
Please excuse my primitive/bad terminology in the following... I'm typing this again after I tabbed and hit backspace, killing all that I wrote before as I went back a page.
I figured out that it wasn't carb, so I figured I had one of two options - ignition or check the timing / pull the cover off
So I chose the easy way. I pulled the caps and wires (caps off the spark plug, wires out of the ignition modules and caps)
I noticed that the rubber in the wires was actually curling around the copper inside! I made sure that the wires were exposing their copper. Some of the wires I had to cut about an 1/8th of an inch off to make sure copper was shining.
I jammed the wires back in the ignition modules and caps and put the caps back on my plugs and VROOOOM, she started faster than ever! It suprised me, even.
Now this still didn't fix the problem completely, but what it did allow me to do was to run at highway speeds again without the bike crapping out. Now it's just when I run up to 9,000 rpm that she wants nothing to do with running on all cylinders.
So I think what I need for the long term is a complete Dyna coil kit for my bike to be reliable. I'm sure anybody on the forums could tell you how great it is, I however have no experience with it.
Anyway, if you could follow that, it might help. Good luck!
-Ian
2006 SV1000S
Carbon Yoshi RS3
ZGDB Smoke Windscreen
Sharealike Clutch Basket Mod
Switchable TRE
13300mi
1981 KZ650 CSR H1
Dual "Pro-Burner" Headlights
ZX-6R Taillight
Tapered Head Bearings
Dyna Wires
Rebel Gears 26T Rear Sprocket
V&H 4-1 Exhaust
20100mi
My little streetfighter...
- rpiian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
- 550A2
I figured it out, but the advice you gave me is a good idea anyway, im actually gonna do it right now...hahah
thx
I recently had the head and cylinders off and i replaced all the top end gaskets. And i tediously made sure everything was in spec.
Thanks
Luke
- leakyseal
- KZ pilot for life.
- bountyhunter
- Thank you received: 337
On my way home i was crusing down my road and i probibly got er up to 7 grand in 4th... when i pull in my driveway the fucking thing lost all its power and it sounds like its running on 1 cylinder!!!!!!!!
When mine did that it was because a piece of crud hit a main jet.
- bountyhunter
Everybody who buys a bike should have a sticker with that on it slapped on their forehead.... I learned it the hard way too.I am gonna use a fuel filter now so this dont happen again.
- KZ250LTD
- Thank you received: 16
I did the same thing with my 750 twin. Put new base gasket, head gasket and rings in. New exhaust. Cleaned everything up. Then one day there was no wind and the sun was shining so I took it up to within 10km of its top speed (not much on the 750 :laugh: ) and lost a cylinder on the way home. I didn't have a garage at the time so the bike was put away for winter a month early. Pulled it out next spring, cleaned the carbs and it ran like a dream :pinch:I recently had the head and cylinders off and i replaced all the top end gaskets. And i tediously made sure everything was in spec.
Thanks
Luke
Agreed! :laugh:
79 KZ1000ST
Past:
Many.
- Old Man Rock
- Thank you received: 225
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
