The Unknown Squeak - Can't Track It Down!
- rpiian
- Live to Ride, Ride to Live
13 Aug 2009 12:03 - 13 Aug 2009 12:05 #313704
by rpiian
2006 SV1000S
Carbon Yoshi RS3
ZGDB Smoke Windscreen
Sharealike Clutch Basket Mod
Switchable TRE
13300mi
1981 KZ650 CSR H1
Dual "Pro-Burner" Headlights
ZX-6R Taillight
Tapered Head Bearings
Dyna Wires
Rebel Gears 26T Rear Sprocket
V&H 4-1 Exhaust
20100mi
My little streetfighter...
The Unknown Squeak - Can't Track It Down! was created by rpiian
Hey guys,
I've been searching in the forums for "noises", "squeaks" and "squeals" and I haven't quite found the results I was looking for. But I'm sure one person on here has had heard this noise.
My bike is a 1981 KZ650 CSR (H1)
It's a low frequency (like 3-4 Hz), modulating squeak that kind of sounds like rubber rubbing against metal or glass. The noise really doesn't really increase in frequency that much. I can hear it from 10 mph all the way until the wind prevents me from hearing it(so like 65+). On the bike it feels like it's traveling from somewhere - where I don't know. I can't locate it while riding.
The first thing I thought of was the chain, but it's new and I lubed it up real nice. I recently installed my new 26 tooth sprocket, so I was wondering about the cush drive these bikes have and if it was contributing. I don't think the gearing change would be stressing my transmission anymore than it normally would; I still try to run in lower gears to keep the bike from bogging. It's not like I'm dealing with increased torque in the rear.
Being on the formula SAE team when I was at school really helped diagnosing engine problems because we ran a 4 cylinder, the F4i, but I have never heard anything like this in my life. It's just really strange and kind of worrying.
Anyone have any thoughts?
-Ian
Ian Duckett
Milton, VT
-Ian
Ian Duckett
Milton, VT
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Last edit: 13 Aug 2009 12:05 by rpiian.
- rpiian
13 Aug 2009 17:48 #313763
by rpiian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Replied by rpiian on topic The Unknown Squeak - Can't Track It Down!
*UPDATE*
The noise sounds more like scratching but it's still periodic, like I mentioned before. After riding today that's what I concluded. Low frequency scratching. Yum.
Also, pulling the clutch does NOT supress it, nor does changing into a different gear, or loading the transmission with full throttle vs. no throttle...
It sounds like something's trying to get out of my motor!! More ponies perhaps? Ahahahahah no...
Anyone have any ideas?
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
- Locozuna
13 Aug 2009 18:33 #313768
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic The Unknown Squeak - Can't Track It Down!
Tach cable? Speedo cable? Tunibrium balancer? Are all the hexagonal fasteners secured?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- bigkaw815
- Thank you received: 1
13 Aug 2009 19:27 - 13 Aug 2009 19:30 #313778
by bigkaw815
Replied by bigkaw815 on topic The Unknown Squeak - Can't Track It Down!
What about the actual speedo or tach? May want to try and spin the cable and see if you can replicate the noise. Other things that ride on rubber mounts- gas tank, seat, cam chain sprockets,...? Also the 81 had a different cam chain tensioner, perhaps the cause. Is it only while riding or can you hear it in a certain rev range?
Last edit: 13 Aug 2009 19:30 by bigkaw815.
- rpiian
14 Aug 2009 03:16 - 14 Aug 2009 04:50 #313834
by rpiian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Yea it seems to be only when riding. I'll check the cables this afternoon and get back to you guys. Thanks!
*Edit*
So I decided to do this before work this morning. I took the cables completely off and drove to work. I still heard the noise, but it's only when rolling. I'm going to guess it's something with the front wheel.
This afternoon the bike is going up and I'm going to spin the front wheel, check out the bearings, and check the speedo assy.
-Ian
*Edit*
-Ian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Last edit: 14 Aug 2009 04:50 by rpiian. Reason: New Info
- IowaKZ
- '80 G1 Classic
- Thank you received: 5
14 Aug 2009 09:19 #313869
by IowaKZ
1980 G1 Classic
Bettendorf, Iowa
Replied by IowaKZ on topic The Unknown Squeak - Can't Track It Down!
could it be a warped brake disc? does the freq increase with a speed increase? I had a warped disc and it made a scratching / rubbing noise.
1980 G1 Classic
Bettendorf, Iowa
- rpiian
14 Aug 2009 09:49 #313879
by rpiian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
I'll have to look into that as well. At first I didn't think that was it because I tried braking hard in the front and it didn't seem to make the noise any louder/intense. I'll take it off and take a look at it for sure!
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
- Kawickrice
- Thank you received: 18
14 Aug 2009 11:16 #313898
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic The Unknown Squeak - Can't Track It Down!
Some times the pads will lay on the rotor and cause a noise. My front brake lever has some play where it goes on the perch and will rattle like hell and I have to rest my pinkie finger on it to keep it from vibrating at certain speeds.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- maestro
14 Aug 2009 16:28 #313941
by maestro
suzuki ts 125 sold
rd250 sold
suzuki 550 es sold
kz1000 a1
Replied by maestro on topic The Unknown Squeak - Can't Track It Down!
hi-just a thought, make sure your front sprockets not come loose i had this last year, makes a real strange noise
good luck
good luck
suzuki ts 125 sold
rd250 sold
suzuki 550 es sold
kz1000 a1
- rpiian
05 Oct 2009 09:27 #325642
by rpiian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
HAHA!! I FOUND IT!
Just as I expected, the noise was traveling from somewhere. Where might you say? The sprocket carrier bearing!!
I was hearing and feeling the noise and vibration on the left case cover.
Before I had put the bike up on the centerstand and gone through the gears, but it wasn't loading the rear sprocket bearing much, so I couldn't hear the noise. I decided to try it again, just for the hell of it, so i violently hammered down in 5th and... Voila! :woohoo:
Apparently, after putting my 26 tooth sprocket on, I didn't tighten the rear axle enough. Leaning the bike in ze turns created some axial and off-axis loading on the bearing - producing some REALLY BAD noises. Towards the end of that poor bearing's life, it basically sounded like I was turning steel on a lathe. :ohmy:
I'm really really glad I found it because a $35 bearing is worth much much less than my life. I mean, not much really could have happened, but when your bike doesn't respond the way you want it to, you might be in trouble given the perfect situation.
Thanks for all your input guys, I really appreciate it. This one's in the books.
-Ian
-Ian
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
- toadson
05 Oct 2009 16:01 #325702
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic The Unknown Squeak - Can't Track It Down!
Bearings will definitely hum when they're going bad, glad you found it! You really don't want anything locking up on a bike, that's for sure.
