Cylinder 3 and 4 arent getting hot
- cricketfire46
13 Aug 2009 11:47 #313696
by cricketfire46
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
Cylinder 3 and 4 arent getting hot was created by cricketfire46
After much reading and trying to figure things out, I have established with a squirt bottle full of water that #3 and #4 are not getting anywhere near the same exhaust temp. after running the bike for a few minutes, i can spray 1 and 2 with water and it is gone almost instantly. when i spray 3 and 4 the water sits for a while. i have also noticed that the plugs in 1 and 2 are staying good while 3 and 4 are fouling (black and carbon on them) rather quickly. the carbs were rebuilt not long ago, and bench synced. i know they should be done with a manometer, but i was told syncing would only better up a good running bike. if anyone has any idea why 3 and 4 are not working right i would appreciate your help.
- pitblue/kz
13 Aug 2009 12:45 #313715
by pitblue/kz
Replied by pitblue/kz on topic Cylinder 3 and 4 arent getting hot
your not getting enough fire is what it sounds like
1st i would change plugs they could be fouled and wires could be a reason for loss of fire
2nd check pick-ups for corrosion or build up
good luck
good luck
- cricketfire46
13 Aug 2009 13:23 #313716
by cricketfire46
Replied by cricketfire46 on topic Cylinder 3 and 4 arent getting hot
just read the service manual. im really new to working on bikes and i cant figure out where the pickups or the electronic control is
