Lets talk crossover pipes
- Born Dead 2
Anyone have any sugestions on if this mod may help.
Thanks in advance
BD
- mzandmz
New to Family, 1979 KZ440 LTD
- Born Dead 2
- N0NB
- Blue handles better
However, the 4 into 2 header system on my KZ650 did not have a crossover built in. I didn't use the bike enough with the header on it to know how it worked and I put a stock system on it before I really started using it.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
With a 4 - 2 system, and if 1 & 2 go to the left and 3 & 4 to the right, and with the 1-2-4-3 firing order, each side fires twice, then rests, while the other side fires twice. Not as efficient for scavenging.
WITH a crossover, my bike runs and sounds slightly better than without. But the difference is very subtle. The low and intermediate torque is just slightly better, but almost undetectable. The sound is more even from each pipe, whereas without the crossover, there is more of a popping from each pipe. I cannot see that any harm would be done to NOT have the crossover, but it is a slight improvement as mentioned above.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- mzandmz
- Born Dead 2
Thanks again for the input.
- Born Dead 2
In the Auto world Experts designed Tuned Headers. Doesn't mean they threw abunch of pipes together and wallah sounds cool. Equil length pipes collected evenly draws exhaust out with a minimal amount of back pressure. Still sounds cool.
So you understand better, My exhaust isn't a bunch of pipes thrown together. All headers are equal lenght into a collector and into slipons. Same as a stock exhaust would be without slipons. I designed it off my 750 with the 4-2 exhaust. Same without xover pipe. It doesn't sound "cool", since I'm not going for the HD sound, but it looks a hell of alot better than a stock pipe. And I built it not bought it which is how I do things.
So I was inquiring to other "builders" for advise.
Thanks anyway for your input.
- mzandmz
- Born Dead 2
- mzandmz
- loudhvx
- Thank you received: 1616
If you combine 1 with 2 and 3 with 4, the pulses are unevenly timed, so one cylinder's pulse will affect the breathing in the other cylinder in an unequal way. You may even have to alter the jetting like the way they are in uneven twins (like the Honda 350 or various v twins).
(KZ 400 and 750 twins are 360 twins so they are evenly timed.)
To get around that problem, you install a crossover pipe to even things out, or combine all four into one at the same point.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
