- Thank you received: 3
vibrations at 4000rpm
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Old Man Rock
- Thank you received: 225
Your bike but for me, oh hell no would I wait... For what I have invested in $$$ & time getting her to where I have the old girl why take a chance and destroying her if it's something that truly is a serious problem waiting to turn real ugly....
It may be normal for her or something simple where the old girl is informing you of major FUBAR coming unless you repair.
4k pending your motor & gearing, this is a common rpm range @ 50-60mph so a good 40% of our driving is spent here... Get off your ass and fix her or at least spend a weekend confirming it's not a serious issue...
Now onto the issues....
"4000rpm the bike vibrates"...
Is it only @ 4krpm or is it a range from 4000-4500 for example?
I realize what you wrote once you pass, just insuring we understand fully...
Is this when riding only or in the garage slowly twist the throttle up and hold her @ 4krpm?
If vibrates in garage....
Are all your engine mounting bolts torqued to specifications?
Have you noticed if it's only in a specific gear when it occurs? Example, rear jacked up (center stand) it doesn't occur in idle or in 3/4 gear no problem, but does occur when shifting from 2nd to 3rd gear etc....
If riding only....
Raise the front end and free spin the tire, is it balanced?
In the manuals, they have a procedure to check your suspensions, front turn radius checks, frame neck bearings etc....
Do the same for the rear tire and suspension...
Ticking sounds...
Timing chain or head exhaust to header leak...
Possibly valve to shim clearance...
This should be a good starting point for you... Others will chime in a swell...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 9am53
If it's happening at a certain engine speed wouldn't that eliminate the tire balancing and suspension possibilities? I would think that if it is happening in all gears ie. at different bike velocities, but at the same engine speed it must be the engine..is this a fair assumption? Or is it in your experience(s) that it may very well be something not directly related to the engine.
One other thing I just remembered, my 550 used to have a similar ticking sound...so I am guessing whatever ails the 550 similarly ails the 1000 only a little moreso.
GEEZ, this is my 3rd edit: When I had my tank off to cahnge my plugs and wires I noticed that this bike has less room between the valve cover and the frame rail than my 550, if I were to take the bike into the shop would they have to remove the engine to do the valve adjustment, or is there enough room to do it with just the tank off? One day when I have my own garage I will not hesitate to do these kinds of things myself, but for now I have to resort to the shop.
'84 GPz900r
'71 CB350
- mzandmz
New to Family, 1979 KZ440 LTD
- 9am53
'84 GPz900r
'71 CB350
- Russ Jackson
- Thank you received: 1
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- 9am53
'84 GPz900r
'71 CB350
- KawiConvert
- Thank you received: 4
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- jswag5
- whats the big deal about harley, i prefer 4 cyls!!
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
- txturbo
- Ex-Kawasaki Mechanic 1981-1985
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- jswag5
my xj750 had a similar issue, it has to do with engine harmonics, i know the early 80s yamaha 750 inlines actually came from the factory with harmonics dampeners(little rubber swuares shoved in between specific cooling fins on the cylinder head) to help eliminate this, maybe you could do something like that to see if it helps.
Thats the information ive acquired straight from yamaha, and it has been seconded by more than one source, the little vibration dampner plugs are available from yamaha still, and i have another source that when i bought some only had to pay pennies compared to the yamaha price. Once i replaced them the bike was extremely smooth, not bad for a few small pieces of rubber and a few dollars even numbness in the hands was lessened by installing them. (i may be willing to divulge if asked nicely) its worth a try, i am planning on ordering another package or 2 to put on the kz here in a few weeks.
i have added the pic of the yamaha head, the absorbers are numbers 11-12(i think they are different sizes, but i was unable to tell the difference) and the part numbers are
11 434-11161-00-00
12 4H7-11161-00-00
82 kz1000p
