Shattered shim/cam follower
- KAWAMIKIE
Now the question is what caused this? The shattered shim, is this what adjusts valve clearance?
Anybody have any used pieces laying around?
81 KZ1000 LTD
08 ZX14 Ninja
- Sandy
- Fly High,Tony
- Thank you received: 13
Where's the shim?
1977 KZ1000 A-1
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Has the head been welded on?
- KAWAMIKIE
I think I got all the pieces of the shim, the were laying rite there.
The cam looks fine, the hole were the follower rides is a little rough around the edges but I'll get it cleaned up.
I'm just wondering if the valve hit the piston and that's what shattered the shim??? I should have done a compression test before I loosened up the timing chain. Now I need to realign the timing marks. I need to get a service manual.
81 KZ1000 LTD
08 ZX14 Ninja
- KAWAMIKIE
What does the cam lobe look like? Is it stock cams? Look in the pan for the shim.
The cam looks fine, must have caught it early enough.
Not sure what you mean by welded on?? I dont see any repairs on it if that's what your talking about. I have most of the shim, if theres more I'm sure I find it when I drop the oil.
Someone has had the valvecover off sometime in it's life, as the bolts were mixmatched.
I'll have to check the cams to see if the are O.E. or not.
81 KZ1000 LTD
08 ZX14 Ninja
- zed1015
- Thank you received: 1554
Dime a dozen as in failing .
It is very rare for a shim to fracture. Could be caused by over revving causing piston to valve contact but it was more common on the early 900's as the shims were slightly dished and kawasaki soon changed the design because of this problem. It is most likely that someone has used an early type shim when doing the clearances . While the top is off i'd inspect the rest just in case there are any more lurking in there. You should get away with just fitting another bucket and shim if this is the case.
- KAWAMIKIE
That's what I'm hoping to do. I just want to get it running good and ride it a bit to see how the trans is working before I tear it all apart and rebuild it.KAWAMIKIE wrote:
81 KZ1000 LTD
08 ZX14 Ninja
- hugo
- '92 Zephyr 750
- Thank you received: 71
- Sandy
- Fly High,Tony
There should be a member close to you,that has spares to...spare...
1977 KZ1000 A-1
- BSKZ650
- Thank you received: 14
also you may want to pull the pan and get all the parts out of it
77 ltd1000, current rider
76 kz900, just waiting
- KAWAMIKIE
81 KZ1000 LTD
08 ZX14 Ninja
