Broken Throttle
- shitimdumb
81 kz650 csr
LS, MO
Thanks!
- TerryK
- Thank you received: 3
I'm fairly new so forgive me on how I describe this, nothing in search gave me an answer. My throttle suddenly lost all resistance on my last ride, I had to get it towed in. When I twist the throttle I can see a little cable being pushed out, but is completely slacked. This cable is in front of the other cable, which is further back. This cable still has plenty of resistance. What do I need to replace and where in my clymer manual do I look?
81 kz650 csr
LS, MO
Thanks!
Sounds like you broke the cable. Pull on the inner part and see if it comes out of the casing.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- shitimdumb
- KZ250LTD
- Thank you received: 16
It sounds like you need the pull cable but either way here's links for both
Push
Pull
Good luck!
79 KZ1000ST
Past:
Many.
- PLUMMEN
- Thank you received: 104
