Horrible Disaster KZ-650E
- sofireguy
12 Aug 2009 14:56 #313426
by sofireguy
Horrible Disaster KZ-650E was created by sofireguy
Hi everyone, I'm new here but I was wanting to see what people's thoughts were on this. I was riding one night with my friends on my 1980 KZ-650E and pulled up to a stop sign and pulled the clutch in 1st. When I pulled it i felt a snap and the bike jumped forward (after the snap the clutch engaged). So I ride home with no clutch since I've done it before with a broken clutch cable.
Well I pulled it apart today to change the cable since it had symptoms of a simple cable snap... Well I pull the chain cover off and it's a holy hell of a mess on the front sprocket. A nice hefty chunk of the crankcase broke off and got caught on the chain and broke the safety plate for the front sprocket.. I'll get some pictures up but I'm pretty sure it's too dangerous to try and weld it back together given it is aluminum and it would be put under high stress from the clutch cable...
Look like a new engine??? :'(
- sofireguy
12 Aug 2009 15:08 #313428
by sofireguy
Replied by sofireguy on topic Horrible Disaster KZ-650E
- vintagestyle7
12 Aug 2009 15:55 #313435
by vintagestyle7
1979 KZ650 B
1975 CB500 T
Replied by vintagestyle7 on topic Horrible Disaster KZ-650E
Where are you located?
1979 KZ650 B
1975 CB500 T
- KawiConvert
- Thank you received: 4
12 Aug 2009 17:27 #313461
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Horrible Disaster KZ-650E
Or go to hydraulic. If its just the cover there are solutions.
- TerryK
- Thank you received: 3
12 Aug 2009 18:13 #313465
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Horrible Disaster KZ-650E
Clearer picture?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- KawiConvert
12 Aug 2009 20:47 #313519
by KawiConvert
On closer look, that appears to be the case next to the neutral switch. Hmm, probably in need of a new upper case. Welding would fix, but may throw other parts off.
- APE Jay
- Banned
- Thank you received: 58
12 Aug 2009 22:34 #313539
by APE Jay
Replied by APE Jay on topic Horrible Disaster KZ-650E
It is a plain bearing crank. Can't just replace the upper case.
- violentvintagecycles
- Thank you received: 1
13 Aug 2009 07:35 #313586
by violentvintagecycles
Replied by violentvintagecycles on topic Horrible Disaster KZ-650E
Happened to me on a suzuki gs 1000.. Loved that bike trashed it after that..
- OnkelB
- Thank you received: 80
17 Aug 2009 12:56 #314610
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Horrible Disaster KZ-650E
No need to panic just yet. Your picture is a bit blurry, but as far as I can tell you have a broken mission cover and a bent clutch pushrod - both parts are replaceable without tearing the engine apart, you will need a new gasket for the mission cover though and probably new seals for output shaft, shift lever shaft and push rod too. Provided there's no damage to the cases themselves it's not too big a deal to fix.
- larrycavan
- Visitor
17 Aug 2009 17:19 #314649
by larrycavan
Replied by larrycavan on topic Horrible Disaster KZ-650E
I agree with OnkelB [how you been Bob :laugh: ...just kidding]
Kind of hard to tell from that pic, but it looks like the trans cover that's broken. If that's so, you're in good shape.
Question is, what caused it? Something get bound up in your chain or what?
