Are the 1973 z1 pistons different????
- 00.
- 1973 kawasaki z1
11 Aug 2009 23:04
Are 1973 z1 pistons different from all of the other z1 bikes. The reason I ask is because I bought a 1973 bike with one piston being different and when I check the compression one piston has lower compression, not sure if it is because of the piston or because of valves or what ever it can be. Please let me know
1973 kawasaki z1
- Mcdroid
- Gone Kwackers
Re: Are the 1973 z1 pistons different????
12 Aug 2009 09:13
I think pistons for the Z1/Z1A/Z1B/KZ900 are the same. If you have mismatched pistons then I'd check the diameter of the bore to see why either one, 3, or all pistons were changed.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- 00.
- 1973 kawasaki z1
12 Aug 2009 11:30
Do you think that a different piston could change the compression from a differnt year z1 bike?? When I look online for new pistons, they show the pistons fitting all year z1 bikes, but not sure if the factory had all same pistons on all years.
1973 kawasaki z1
- Mcdroid
- Gone Kwackers
12 Aug 2009 11:37 - 12 Aug 2009 12:24
00. wrote:
Kawasaki ( www.kawasaki.com ) shows the same part number for standard pistons for Z1/Z1A/Z1B/KZ900
It is possible for a piston with a different shaped top surface to change compression numbers...you need to find out if they are aftermarket pistons and who the manufacturer(s) are. You might start down that road by measuring the diameter of the bore to get some ideas of what the previous owners have done to the bike.
I just read your other thread...so you re-ringed but used the same pistons? And one of those pistons differs from the other three...if so, how exactly does it differ?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 12 Aug 2009 12:24 by Mcdroid.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
12 Aug 2009 14:52
Do all the pistons, have the same wrist pin height?
