1973 z1 Help on COMPRESSION
- 00.
- 1973 kawasaki z1
1973 kawasaki z1
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
- txturbo
- Ex-Kawasaki Mechanic 1981-1985
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
- txturbo
Something is not right with #3. First check the valve clearance. If thats ok, redo the compression check then do #3 again but with some oil squirted into the cylinder. If the compression comes up there is something wrong with the rings. If it stays the same then a valve is leaking. Were the valves lapped?I have just finished rebuilding my 1973 z1 engine, new piston rings, all new gaskets, valve seals, basically the head is totally rebuilt. The bike runs fine, but when I check the compression; number 1,2,4 cylinder gets 180psi and #3 piston gets 150psi. But the book said that the compression should be 130-160psi, so why do I have 3 pistons that have 180psi? Also why would one cylinder have lower compression than the other three, can it be valves not adjusted properly? Or can it be some other problem. Please help....
1984 ZX1100 A2 GPz
1984 ZX900
1969 Camaro SS
1966 Impala
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- 00.
- 1973 kawasaki z1
1973 kawasaki z1
- BSKZ650
yes a valve too thight,, ie, no clearance and holding the valve open will "leak" since the valve is not allowed to close all the way.
yes a valve that is shimmed too tight, but still has clearance can make the compression number lower since it is holding the valve open longer and opening it sooner,, ie, letting more air escape prior to compression.
and the same can be held true if its not allowed to open fully and thus get the proper amount of air in the cyl.
its always a good idea to run it for a few hours, retorque the head bolts, and re check the valves, just good practice.
I still think its not fully broke in, meaniong the rings still have not fully seated
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Does it run good?
Is it running on four cylinders?
Did you do a valve job, with your rebuild?
- 00.
- 1973 kawasaki z1
1973 kawasaki z1
- nads.com
- Thank you received: 20
