- Thank you received: 1
dads kz550 has trouble starting
- violentvintagecycles
- loudhvx
- Thank you received: 1616
Those choke flaps have to seal completely at the initial start if the bike is modded to breath more.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- GPz550D1
- Thank you received: 22
YEah, I was amazed at how hard it was to start my one bike that had a big 4-into-1, until I fixed the choke pins. Then it started easy every time. ( I was using starting fluid sometimes so I wouldn't drain the battery while cranking.)
How did you fix those pins? Epoxy or solder? Thanks for the pictures.
Robert
1981 KZ550-D1
- GPz550D1
Hey, Vvc, do you start the bike in the prime position? Just wondering if you've tried that. If my bikes sit for a day or two, I have to flip it to prime for about 30 seconds to get fuel in the carbs. Two hours shouldn't need it though.
I have to turn my Gpz550 to prime also if it is not used for 4 days or more. Wonder why the gas in the float bowls evaporates/disappears?
Robert
1981 KZ550-D1
- loudhvx
Robert
I very, very gently peened the casting around the shaft, but it's too brittle and I don't recommend this method. It would be too easy to break a chunk of the casting off. I don't know why I didn't think of it at the time, but I think loctite or some other glue or epoxy would be a much better solution.
1981 KZ550 D1 gpz.
Other links.
