650 - 750 engine swap
- Invicta 39
11 Aug 2009 11:20 #313157
by Invicta 39
650 - 750 engine swap was created by Invicta 39
I have a 650 chain drive bike and a 750 shaft drive motor, I want to use the 750 motor and keep the chain drive.
1. Is this possible
2. what are the issue with the swap.
1. Is this possible
- KawiConvert
- Thank you received: 4
11 Aug 2009 12:30 #313173
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic 650 - 750 engine swap
I'd suggest putting the 750 jugs on the 650 lower. Swapping transmission components may prove difficult.
- anarki650
- Thank you received: 5
11 Aug 2009 12:44 #313175
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic 650 - 750 engine swap
If you go that route (jugs on the 650 bottom end) you'll have to increase the size of the openings on the crankcase so the bigger pistons don't slap. Also, if the 750 motor isn't from a really early 750 you'll have issues stemming from the different types of cam chains. Most of the 750 motors used a hyvo chain while the 650's used the standard link type. The hyvo motors don't have the same cam chain tensioners so you wouldn't be able to run the same cam chain, which would lead to splitting the cases to swap out the crank anyway, which if you're going to have to do that you may as well split the cases and swap out the transmissions....
09 Kawasaki ER6n
Omaha NE
- KawiConvert
11 Aug 2009 14:44 #313187
by KawiConvert
anarki650 wrote:
Good point! On the shafty, does the shaft output bolt onto the engine or is it cast into the cases? Would it work instead to swap the swingarms and rear wheels?
- Invicta 39
12 Aug 2009 14:47 #313423
by Invicta 39
Replied by Invicta 39 on topic 650 - 750 engine swap
If I split the cases, can I drop the 750 crank into the 650 case and put the jugs on from there?
- anarki650
12 Aug 2009 15:55 - 12 Aug 2009 15:58 #313437
by anarki650
09 Kawasaki ER6n
Omaha NE
Yes, I think, you'll just have to increase the size of the top openings on the 650 top case so that the piston skirts won't slap on the down stroke. Those don't have to be machined exact, I've heard from several people that they did it with a dremel or other small grinder in their garage with no ill effect on the motor.
I say I think because I'm not 100% sure that the top of the case is the same between the motors...
09 Kawasaki ER6n
Omaha NE
Last edit: 12 Aug 2009 15:58 by anarki650.
