KZ650 Engine Clunking?
- mzandmz
11 Aug 2009 10:10 #313139
by mzandmz
New to Family, 1979 KZ440 LTD
KZ650 Engine Clunking? was created by mzandmz
My 77 KZ650 has always had a lower end clunking noise,Sounds like the HYVO chain slack. I hear its a common noise,?or is it.And how bad are they.At what point do you get concerned? It makes alot of noise when cold and at a low Idle.(under 1100rpms) It will make noise if you lug it. Once warm it only clunks a little at about 950rpms.Only has 10,000 miles on the engine. After I replaced the points and did the timing it got a lot softer. Ran better.
- Thank you received: 2098
11 Aug 2009 10:21 #313142
by Patton
Replied by Patton on topic KZ650 Engine Clunking?
mzandmz wrote:
And will likely get even softer and quieter after a good carb sync.
Good Luck!
Good Luck!
- anarki650
- Thank you received: 5
11 Aug 2009 11:35 #313163
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic KZ650 Engine Clunking?
+1 on the carb sync. If that doesn't totally remove the noise try bumping your idle speed up just a touch. 950 on the tach may not be an actual 950 rpm, these gauges are faaaarrrr from being dead on accurate.
09 Kawasaki ER6n
Omaha NE
- mzandmz
11 Aug 2009 18:04 #313227
by mzandmz
Replied by mzandmz on topic KZ650 Engine Clunking?
Hey Guys, I took off my Carbs and found out the guy that rebuilt them forgot to clean number 3 carb very good and the choke circit was plugged. plus the float needle was stuck in the closed position. 3banger. I cleaned it out and never had so much power before and my clunking is barly there.SMOOOOOOOOTH RUNNING She is.:woohoo:
