Pulling baffle out?
- likes2gofast2009
10 Aug 2009 18:48 #313017
by likes2gofast2009
I was told its a vance and hines pipe, I can't figure out how to get the baffle out...Anyone have any ideas? I pulled the one screw that goes through the pipe and baffle, but it won't budge...
1980 KZ1000 LTD "Brandi"
4-1 Kerker
Dyna Coils
More to come this winter!
Pulling baffle out? was created by likes2gofast2009
4-1 Kerker
Dyna Coils
- trianglelaguna
- Thank you received: 235
10 Aug 2009 19:01 #313020
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Pulling baffle out?
they get in there pretty good after time...if you do get it out you may have to bang it up to put er back in...if your pipe is in good shape???go slow....try tapping with a rubber mallet and a bath towel to deaden the mallet.....tap it in circles around and up to about two nfeet up...if your lucky and it is a two peice you can pull the can and use the mallet and a wood insert...it can dent easy and quick though...if it is not a two peice you can try a hooked peice of metal in a t handle and tap while pulling onj the core...good luck....doesn't look like a vance and hines to me but that pic could be better......peace
1976 KZ900
2003 ZX12R
2007 FZ1000
- rt green
10 Aug 2009 20:08 #313040
by rt green
Replied by rt green on topic Pulling baffle out?
i used some carb cleaner to soften up the carbon a bit. let it sit in there awhile. then i used an automotive bearing puller for a differental axle bearings on the end of a slide hammer. came right out
- 550A2
- keep the shiny side up
- Thank you received: 1
10 Aug 2009 20:38 #313042
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic Pulling baffle out?
They do get stuck in there good! hahah.
man, mine aint a vance and hiens but it was a bitch to pull out! I ended up disconnecting it where the header connects to the tail pipe then pounding it out from the other direction with a piece of tubing.
I agree with the other guys though, try that and if you cant get it out then.......
good luck, these inline fours are gnarly loud sounding without the baffle.
- 2006hhr
10 Aug 2009 21:53 #313053
by 2006hhr
Replied by 2006hhr on topic Pulling baffle out?
Looks like a Mac pipe.
- bountyhunter
- Thank you received: 337
10 Aug 2009 22:14 - 10 Aug 2009 22:16 #313057
by bountyhunter
Replied by bountyhunter on topic Pulling baffle out?
likes2gofast2009 wrote:
It's rusted itself to the inside of the can. My Mac muffler has the same problem. You might try taking it off the header andhosing the insides with penetrating oil like Kroil or PB Blaster.I pulled the one screw that goes through the pipe and baffle, but it won't budge...
Last edit: 10 Aug 2009 22:16 by bountyhunter.
- likes2gofast2009
11 Aug 2009 12:06 #313169
by likes2gofast2009
4-1 Kerker
Dyna Coils
Replied by likes2gofast2009 on topic Pulling baffle out?
Thanks for all the tips guys, I pulled the pipe off, its separate from the header itself, and tried pounding it out but gave up due to the 90 degree weather and 50% humidity... I'll give it another try on a rainy day.
4-1 Kerker
Dyna Coils
