Starter Clutch
- BIGD
10 Aug 2009 06:35 #312912
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Starter Clutch was created by BIGD
I have removed all covers, am at the alternator rotor. Ordered a alternator rotor holder from my original manual and was defaulted to another type of holder from Kawasaki that does not look or perform like the original. It is not strong enough to hold the rotor while trying to undo the bolt holding the rotor. The original holder from Kawasaki is not available anymore. Is there someone who could tell me what with, or how to hold the rotor while I remove the bolt. I believe this bolt has never been removed in 29 years, and probably still has the original lock tight on it. The 3 bolts on my starter clutch are lose or broken and need replacing. Thanks in advance BIGD
- Sandy
- Fly High,Tony
- Thank you received: 13
10 Aug 2009 08:21 #312926
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Starter Clutch
Get one of those serpentine grabbers,basically a rubber belt that grabs onto round items,like removing a stuck lid on a jar,if that makes any sense.
Get someone to hold that in place and hit that bolt with an impact gun.
1977 KZ1000 A-1
- MFolks
- Thank you received: 540
10 Aug 2009 11:03 #312949
by MFolks
Replied by MFolks on topic Starter Clutch
Most 1/2" drive air impact wrenches will make short work of the bolt this size.
- bountyhunter
- Thank you received: 337
10 Aug 2009 13:20 #312962
by bountyhunter
Replied by bountyhunter on topic Starter Clutch
I used a huge flat blade screwdriver with the tip hooked into the hole in the flywheel with the end of the screwdriver resting against the metal frame pins that mount the footpeg.
BTW, I think you will have better luck loosening the nut if you put a wrench on and tap the handle with a hammer.
IMPORTANT: That nut on mine is a reverse thread. Not sure about yours, but make sure you are turning yours the correct way.
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
10 Aug 2009 13:45 #312967
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic Starter Clutch
You can put the bike into 1st gear and have someone stand on the brake lever while you hit the bolt with an impact air driver. I've also wedged a screwdriver in between the gear teeth to keep from rotating. If I recall correctly the bolt is a regular right-hand thread.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
