Piston Pin Removal
- KevZ
Piston Pin Removal
15 Mar 2006 04:01
I am in the process of disassembling my KZ1100 motor, and I cannot remove the piston pins. My manual says that the pin should be able to be pushed out by finger. I couldn't move them at all by finger. Then the manual says to heat the piston with a warm rag, and then push the pin out. That helped move the pin on #1 piston to be in line with the connecting rod. The manual says if the pin still will not come out, use a C-clamp and a rod to push the pin out. I do not want to damage the connecting rods, so I was wondering if anyone has any ideas or alternatives. What is the risk of damaging the piston by using a C-clamp?
- RonKZ650
Re: Piston Pin Removal
15 Mar 2006 07:00
They come right out using a c-clamp. Use a short piece of pvc pipe or similar with an ID larger than the pin, set it against the piston, then use the c-clamp to press the pin right out into the pipe. Takes very little effort and no damage.
- KevZ
- APE Jay
15 Mar 2006 14:20
Usually the pin has been banging against the clip and raises a burr on the clip grooves. This is what you have a problem with. After you get the piston off, you can deburr the pin hole at the groove and the pin should then slide right through on assembly.
Jay
Jay
- brianrae33
17 Mar 2006 09:33
or you can get a small butane torch and heat the piston just until its hot to the touch....pin will slide right out..
1982 kz1000ltd
- KevZ
17 Mar 2006 09:47
I got them out the other day. Interesting explanation of the burrs on the clip grooves. I will check into this. It didn't even cross my mind.
