leaky cam cover
- brianrae33
1982 kz1000ltd
- terry s
- bountyhunter
- Thank you received: 337
At some point in the life of the end caps, I had to take them out and clean them and the head surfaces thoroughly and re-install them with good sealer (the FSM calls out sealer must be used on the rubber plugs). When you put the cover and gasket on, you have to run a bead of sealer AT LEAST over the end plugs or they will leak every time. At least, mine does.82 kz1000..just put gpz 1000 cams in her..new cam cover gasket but now it's leakin' worse..should i permatex the end caps?? appears to be where it's coming from..
- racer54
- Thank you received: 114
- HerrDeacon
- Old Man Rock
- Thank you received: 225
Permatex Copper Spray Gasket Adhesive Sealant.... Spary both sides of your gaskets, let flash for a minute or two and the gaskets won't leak with proper torque...
The nice thing about this spray is it also helps prevent the gaskets from burning into (sticking) the aluminum surfaces...
On the end caps, I have FBG end aluminum plugs so I use a little Permatex RTV (the high temp orange one) on the end caps as well.... Again, no leaky!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- brianrae33
1982 kz1000ltd
- roy-b-boy-b
- Thank you received: 103
- RonKZ650
- Thank you received: 240
- MDawnz1
- Thank you received: 27
Use Yamabond or Threebond or something like that.
AND don't use much .
You can "paint" the stuff on with a toothpick or a matchstick .
Works great.
Stay away from RTV ,
The only place for that on a bike is in the rear hub to take some of the slop out of your drive dampers.
1974 Z1a, still 903
