'82 KZ1100 Spectre cylinder not firing....
- Sooner7926
- PLUMMEN
- Thank you received: 104
- TerryK
- Thank you received: 3
are you getting fire from 2/3 coil ?
That's what I was thinking.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Sooner7926
I tested the #2 plug and it was getting a pretty good spark. I didn't test #3 because it was working yesterday. I was thinking it had to be a fuel delivery problem, but I'm not sure what would have changed in 1 day. the carbs look clean.
- MFolks
- Thank you received: 540
Where they are mounted under the tank is not the best place for cooling.
I'd replace the sparkplugs wires and caps as they fail after a few years. I believe 7mm sparkplug wires fit the coils and caps.
- Sooner7926
How old are the ignition coils? Could be breaking down.
They're probably pretty old. I have no way of knowing. I'll try replacing the plugs and wires and see if that helps before I replace the coils. Thanks for your help.
- TerryK
Don't start spending a bunch of money on parts you may not need. You can check wires, caps and coils to see if they are still serviceable. Just follow the instructions in a shop manual. Besides, didn't you say you had good spark? Have you delved deeper into the carbs?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- violentvintagecycles
