Bolt size?
- roccbottom
- 1984 gpz1100, 1995 kz1000p
07 Aug 2009 15:03 #312274
by roccbottom
Bolt size? was created by roccbottom
Hello to all.This is my first post.so I ask for your patience on this matter. I have a 1983 gpz 1100.I am staying busy making road worthy. My question is what size is the bolt,that fastens thestarter clutch and the outter stator assembly ,to the crank shaft.Mines was not there,or it was swollowed by the engine,i've dropped the oil pan but it was not there. your help and suggestions are greatly appreciated.
- Royal1MC
- Is it just me, or is it just great to be on a KZ
07 Aug 2009 16:53 #312286
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic Bolt size?
Is this the bolt you need # 92001?
If so part is still available @ the Kawasaki dealer.
Bolt is 12x40.
Bolt is 12x40.
Los Angeles, CA
- Royal1MC
07 Aug 2009 16:56 #312287
by Royal1MC
Los Angeles, CA
Royal1MC wrote:
Sorry had to convert to jpeg file ext
Bolt is 12x40.
Los Angeles, CA
- MFolks
- Thank you received: 540
07 Aug 2009 16:59 #312288
by MFolks
Replied by MFolks on topic Bolt size?
Looking at my shop manual on my 82 GPZ1100 B2 model I see the Alternator Rotor Bolt listed as a 12 X 1.25 X 40MM bolt torqued to 94 FOOT POUNDS.
I'd suggest using a good spray degreaser on the replacement bolt and in the hole to throughly clean it, and then use some good Blue Loctite or similar thread locking compound on the threads(just a drop or two is needed).
Don't use any of the RED Loctite as it will require at least 300 F to loosen it's grip, far more than the magnetic rotor can stand.
Holding the Alternator Stator to the inside of the left engine cover is three 6 x 1.0 x 30 Allen head bolts torqued to 87 INCH POUNDS.
Any other questions I can help with?
- roccbottom
07 Aug 2009 20:43 #312325
by roccbottom
Replied by roccbottom on topic Bolt size?
Thank you my kz family.Thats exactly the part I need.And i'll take the advice for the loctite.Once again your help is greatly appreciated.
