Oil Light ON - What the heck Please help
- KOOL RYDER
- KZ 650B2 / KZ 1000E
07 Aug 2009 09:10 #312205
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Oil Light ON - What the heck Please help was created by KOOL RYDER
Gentlemen:
I just did the WG power mod on the bike and it has rained here for 4 days straight. This morning I went to start the bike (first time since monday) and the oil light was on.
I checked the oil window and I have oil up to and just under the top level mark and the oil is circulating (I can see that in the oil window).
What could the problem be? I have not fooled with the oil filter / changed oil. The light is just on. I have not had this problem before.
What could it be? Other than that after firing up the bike it worked fine. But seeing the oil light on I sht the bike down just in case.
Any ideas?
Any ideas?
1978 KZ650B
1979 KZ1000ST
- anarki650
- Thank you received: 5
07 Aug 2009 09:21 #312207
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Oil Light ON - What the heck Please help
Check to make sure the wire off the switch isn't grounding anywhere. I had that problem with my 650 and it was just the connector from the wire hitting the back of the points plate and grounding out.
09 Kawasaki ER6n
Omaha NE
- KOOL RYDER
07 Aug 2009 09:55 - 07 Aug 2009 09:56 #312209
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic Oil Light ON - What the heck Please help
Thanks for the help so far. Just for your info, we did have the points plate off to adjust the timing and points, one wire was freyed going to the 1/4 points side and we solidered it.
Can you please provide me additional information on where the problem is occuring under the points plate, such as where the possible ground would be?
Ie. Where is the switch and where is the wire off of the switch connected?
1978 KZ650B
1979 KZ1000ST
Last edit: 07 Aug 2009 09:56 by KOOL RYDER.
- mzandmz
07 Aug 2009 09:56 #312211
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Oil Light ON - What the heck Please help
How old is your Oil Sending Unit? Sometimes they will stop working before they start Leaking oil. Rain will reak havic on older connections, I live on the coast with alot of continuing moisture. Electric connections are checked often to ensure proper voltage and no corrosion. Just a few Ideas.
- KOOL RYDER
07 Aug 2009 10:13 #312216
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
Thanks again. I am still looking for a diagram that will show where the possible ground will be under the points cover. I would like to ride the old girl this weekend so any help would help.
1978 KZ650B
1979 KZ1000ST
- mzandmz
07 Aug 2009 10:23 #312220
by mzandmz
- bill_wilcox100
07 Aug 2009 11:41 - 07 Aug 2009 11:44 #312240
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Oil Light ON - What the heck Please help
Here's a pic. Hope it helps.
The Oil Pressure Sending Unit is just under the timing plate. See lower right, where the Blue/Red wire disappears under the timing plate. Remove the plate to look for a short.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 07 Aug 2009 11:44 by bill_wilcox100.
- JakeB
07 Aug 2009 14:14 - 07 Aug 2009 14:15 #312269
by JakeB
1978 Z1-R
Replied by JakeB on topic Oil Light ON - What the heck Please help
I'd check the switch first, if it works you most likely have a short. If it doesn't work you aren't spending a time looking for a short that may or may not be there!
1978 Z1-R
Last edit: 07 Aug 2009 14:15 by JakeB.
- KOOL RYDER
10 Aug 2009 09:10 #312941
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
Problem solved. I guess when we had the points plae off we must have pulled the wire a little and it became partially separated. Fixed the problem in 3 mins.
Thanks for the help.
KRB)
KRB)
1978 KZ650B
1979 KZ1000ST
- Mark Wing
- Thank you received: 22
10 Aug 2009 11:51 #312953
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Oil Light ON - What the heck Please help
mzandmz wrote:
The drawing is fine, it's the writing that's in question. :woohoo:
Mark
Please excuse the poor drawing
Mark
Yorba Linda Cal.
